Node works but screen stuck on "Stopping existing containers"
Long story short, running UmbrelOS on Raspberry Pi. Power outage happened. Turned it back on. Node still runs, and I can send/receive payments via ZeusLN, and the channels are still marked as “active,” as far as I can see.
However, when I try to access the home page, via my IP or umbrel.local, I only get the “Stopping existing containers…” message. And it’s been stuck there for at least 16 hours.
I’ve tried the standard “sudo systemctl stop umbrel-startup.service && docker system prune --force --all && sudo systemctl start umbrel-startup.service” fix, but nothing has changed. I’ve also reflashed UmbrelOS. But to no avail.
The logs tell me there is perhaps an issue with Tor, but perhaps there is another fix I haven’t thought of.
Does anyone have any idea for a fix? Thank you.
debug log below:
0.5.0
Flashed OS version
v0.5.0
Raspberry Pi Model
Revision : c03112
Serial : 10000000aa7443a8
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
Dec 1 2021 15:01:54
Copyright (c) 2012 Broadcom
Temperature
temp=43.3’C
Throttling
throttled=0x0
Mem: 3.8G 2.8G 236M 13M 730M 839M
Swap: 4.1G 1.3G 2.8G
total: 74.5%
bitcoin: 18.2%
system: 13.3%
ln-visualizer: 8.4%
lightning: 7.7%
woofbot: 5.6%
electrs: 5.2%
mempool: 4.5%
thunderhub: 3.6%
bitfeed: 2.6%
bluewallet: 2.5%
helipad: 0.9%
vaultwarden: 0.8%
tor: 0.7%
tailscale: 0.5%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
2022-08-17 08:05:53 Memory monitor running!
26912 ? S 0:00 bash ./scripts/memory-monitor
2022-08-17 08:35:44 Memory monitor running!
2022-08-17 09:20:22 Memory monitor running!
11556 ? S 0:00 bash ./scripts/memory-monitor
/dev/root 29G 3.2G 25G 12% /
/dev/sda1 916G 543G 327G 63% /home/umbrel/umbrel
Startup service logs
Aug 17 09:34:45 umbrel umbrel startup[11535]: Creating electrs_tor_server_1 …
Aug 17 09:34:45 umbrel umbrel startup[11535]: Creating electrs_app_proxy_1 …
Aug 17 09:35:01 umbrel umbrel startup[11535]: Creating mempool_tor_server_1 … done
Aug 17 09:35:01 umbrel umbrel startup[11535]: Creating electrs_tor_server_1 … done
Aug 17 09:35:02 umbrel umbrel startup[11535]: Creating thunderhub_tor_server_1 … done
Aug 17 09:35:04 umbrel umbrel startup[11535]: Creating electrs_electrs_1 … done
Aug 17 09:35:04 umbrel umbrel startup[11535]: Creating electrs_app_proxy_1 … done
Aug 17 09:35:04 umbrel umbrel startup[11535]: Creating electrs_app_1 …
Aug 17 09:35:04 umbrel umbrel startup[11535]: Creating mempool_mariadb_1 … done
Aug 17 09:35:05 umbrel umbrel startup[11535]: Creating thunderhub_web_1 … done
Aug 17 09:35:05 umbrel umbrel startup[11535]: Creating mempool_web_1 … done
Aug 17 09:35:05 umbrel umbrel startup[11535]: Creating thunderhub_app_proxy_1 … done
Aug 17 09:35:05 umbrel umbrel startup[11535]: Creating mempool_api_1 … done
Aug 17 09:35:06 umbrel umbrel startup[11535]: Creating mempool_app_proxy_1 … done
Aug 17 09:35:11 umbrel umbrel startup[11535]: Creating electrs_app_1 … done
Aug 17 09:35:16 umbrel umbrel startup[11535]: Digest: sha256:bfcc02f752963eaf9f9c3bf2776e032194d218b0037f3c54ed19d8872a7f241b
Aug 17 09:35:16 umbrel umbrel startup[11535]: Status: Downloaded newer image for woofbot/woofbot@sha256:bfcc02f752963eaf9f9c3bf2776e032194d218b0037f3c54ed19d8872a7f241b
Aug 17 09:35:16 umbrel umbrel startup[11535]: Creating woofbot_tor_server_1 …
Aug 17 09:35:17 umbrel umbrel startup[11535]: Creating woofbot_app_proxy_1 …
Aug 17 09:35:17 umbrel umbrel startup[11535]: Creating woofbot_mongodb_1 …
Aug 17 09:35:24 umbrel umbrel startup[11535]: Creating woofbot_tor_server_1 … done
Aug 17 09:35:24 umbrel umbrel startup[11535]: Creating woofbot_mongodb_1 … done
Aug 17 09:35:24 umbrel umbrel startup[11535]: Creating woofbot_web_1 …
Aug 17 09:35:24 umbrel umbrel startup[11535]: Creating woofbot_app_proxy_1 … done
Aug 17 09:35:30 umbrel umbrel startup[11535]: Creating woofbot_web_1 … done
Aug 17 09:35:31 umbrel umbrel startup[11535]: Umbrel is now accessible at
Aug 17 09:35:31 umbrel umbrel startup[11535]: http://umbrel.local
Aug 17 09:35:31 umbrel umbrel startup[11535]: [redacted]
Aug 17 09:35:31 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
– Logs begin at Wed 2022-08-17 07:59:35 UTC, end at Wed 2022-08-17 10:12:08 UTC. –
Aug 17 07:59:40 umbrel systemd[1]: Starting External Storage Mounter…
Aug 17 07:59:40 umbrel external storage mounter[506]: Running external storage mount script…
Aug 17 07:59:40 umbrel external storage mounter[506]: Found device "SABRENT "
Aug 17 07:59:40 umbrel external storage mounter[506]: Blacklisting USB device IDs against UAS driver…
Aug 17 07:59:40 umbrel external storage mounter[506]: Rebinding USB drivers…
Aug 17 07:59:40 umbrel external storage mounter[506]: Checking USB devices are back…
Aug 17 07:59:40 umbrel external storage mounter[506]: Waiting for USB devices…
Aug 17 07:59:41 umbrel external storage mounter[506]: Waiting for USB devices…
Aug 17 07:59:42 umbrel external storage mounter[506]: Checking if the device is ext4…
Aug 17 07:59:42 umbrel external storage mounter[506]: Yes, it is ext4
Aug 17 07:59:42 umbrel external storage mounter[506]: Checking if device contains an Umbrel install…
Aug 17 07:59:42 umbrel external storage mounter[506]: Yes, it contains an Umbrel install
Aug 17 07:59:42 umbrel external storage mounter[506]: Bind mounting external storage over local Umbrel installation…
Aug 17 07:59:42 umbrel external storage mounter[506]: Bind mounting external storage over local Docker data dir…
Aug 17 07:59:42 umbrel external storage mounter[506]: Bind mounting external storage to /swap
Aug 17 07:59:42 umbrel external storage mounter[506]: Bind mounting SD card root at /sd-card…
Aug 17 07:59:42 umbrel external storage mounter[506]: Checking Umbrel root is now on external storage…
Aug 17 07:59:44 umbrel external storage mounter[506]: Checking /var/lib/docker is now on external storage…
Aug 17 07:59:44 umbrel external storage mounter[506]: Checking /swap is now on external storage…
Aug 17 07:59:44 umbrel external storage mounter[506]: Setting up swapfile
Aug 17 07:59:44 umbrel external storage mounter[506]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Aug 17 07:59:44 umbrel external storage mounter[506]: no label, UUID=36ac67af-20ae-43b7-96ec-0cd73dda0f47
Aug 17 07:59:44 umbrel external storage mounter[506]: Checking SD Card root is bind mounted at /sd-root…
Aug 17 07:59:44 umbrel external storage mounter[506]: Starting external drive mount monitor…
Aug 17 07:59:44 umbrel external storage mounter[506]: Mount script completed successfully!
Aug 17 07:59:44 umbrel systemd[1]: Started External Storage Mounter.
Aug 17 08:00:27 umbrel systemd[1]: Starting External Storage SDcard Updater…
Aug 17 08:00:27 umbrel external storage updater[3772]: Checking if SD card Umbrel is newer than external storage…
Aug 17 08:00:27 umbrel external storage updater[3772]: No, SD version is not newer, exiting.
Aug 17 08:00:27 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
./karen: line 68: /home/umbrel/umbrel/events/triggers/: Is a directory
3922 ? S 0:00 bash ./karen
3986 ? S 0:00 bash ./karen
karen is already running
Got signal:
karen is getting triggered!
Got signal:
Got signal:
Got signal:
Got signal:
26900 ? S 0:00 bash ./karen
26951 ? S 0:00 bash ./karen
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
11544 ? S 0:00 bash ./karen
11579 ? S 0:00 bash ./karen
Docker containers
NAMES STATUS
ln-visualizer_web_1 Up 26 minutes
ln-visualizer_tor_server_1 Up 26 minutes
ln-visualizer_api_1 Up 26 minutes
ln-visualizer_app_proxy_1 Up 26 minutes
woofbot_web_1 Up 37 minutes
woofbot_mongodb_1 Up 37 minutes
woofbot_app_proxy_1 Up 37 minutes
woofbot_tor_server_1 Up 37 minutes
electrs_app_1 Up 37 minutes
electrs_electrs_1 Up 37 minutes
electrs_app_proxy_1 Up 37 minutes
electrs_tor_server_1 Up 38 minutes
thunderhub_app_proxy_1 Up 37 minutes
thunderhub_tor_server_1 Up 37 minutes
thunderhub_web_1 Up 37 minutes
mempool_web_1 Up 37 minutes
mempool_mariadb_1 Up 37 minutes
mempool_app_proxy_1 Up 37 minutes
mempool_tor_server_1 Up 38 minutes
mempool_api_1 Up 37 minutes
bitfeed_web_1 Up 41 minutes
bitfeed_tor_server_1 Up 41 minutes
bitfeed_api_1 Up 41 minutes
bitfeed_app_proxy_1 Up 41 minutes
lightning_lnd_1 Up 42 minutes
lightning_tor_server_1 Up 42 minutes
lightning_app_proxy_1 Up 42 minutes
lightning_app_1 Up 42 minutes
bitcoin_server_1 Up 43 minutes
bitcoin_bitcoind_1 Up 43 minutes
bitcoin_app_proxy_1 Up 43 minutes
bitcoin_tor_server_1 Up 43 minutes
bluewallet_lndhub_1 Up 36 minutes
bluewallet_redis_1 Up 44 minutes
bluewallet_tor_server_1 Up 44 minutes
bluewallet_app_proxy_1 Up 44 minutes
helipad_web_1 Up 41 minutes
helipad_tor_server_1 Up 45 minutes
helipad_app_proxy_1 Up 45 minutes
tailscale_tor_server_1 Restarting (1) 54 seconds ago
tailscale_web_1 Up 45 minutes
vaultwarden_app_proxy_1 Up 45 minutes
vaultwarden_server_1 Up 45 minutes (healthy)
vaultwarden_tor_server_1 Up 45 minutes
middleware Up 49 minutes
nginx Up 49 minutes
manager Up 49 minutes
auth Up 49 minutes
dashboard Up 49 minutes
tor Up 49 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:12:44 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:12:46 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:12:48 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:12:50 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:12:52 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:12:54 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:12:56 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:12:58 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:13:00 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 17 Aug 2022 10:13:02 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.5112.81 Safari/537.36”
manager |
Tor logs
Attaching to tor
tor | Aug 17 09:47:48.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $887CAB501A9DB68A2C44EDF98BF50B0304EED8B6~relayonkostchtchie [aOmsqBCzWvW9eV9YaqzEpjf+iVobicNGwngG9OQgyK8] at 185.220.100.249. Retrying on a new circuit.
tor | Aug 17 09:48:03.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $719FD0FA327F3CCBCDA0D4EA74C15EA110338942~F3Netze [Nx05iIqVlLft1v1insRjzT1YbtgXFX+qRtxygcI7GC8] at 185.220.100.252. Retrying on a new circuit.
tor | Aug 17 09:49:44.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | Aug 17 09:54:38.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $D80F649226CC96BBE0FF7B45B3791901569FE5AC~ForPrivacyNET [6NWpeYq8i0MyD4V1LuVXyOxkdy4PK8h3Dr9MqxN2+tE] at 185.220.101.38. Retrying on a new circuit.
tor | Aug 17 09:54:53.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $E8C8667CAF3D5148E52ECF736A7B204982F78EAA~F3Netze [Czc9qIZzJbWBh5rxuvc/KX3NF4biZWOIHri5FtWVPRs] at 185.220.100.254. Retrying on a new circuit.
tor | Aug 17 09:55:08.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $D71B1CA1C9DC7E8CA64158E106AD770A21160FEE~Unnamed [iqHwJ4i9/ga1xAx9o88YkdzGl0cXFCDuBZlcNGh0NkE] at 185.34.33.2. Retrying on a new circuit.
tor | Aug 17 09:55:12.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | Aug 17 10:10:38.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | Aug 17 10:10:57.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | Aug 17 10:12:49.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
App logs
bitcoin
tor_server_1 | Aug 17 09:29:05.998 [notice] Tor can’t help you if you use it wrong! Learn how to be safe at https://support.torproject.org/faq/staying-anonymous/
tor_server_1 | Aug 17 09:29:06.046 [notice] Read configuration file “/etc/tor/torrc”.
tor_server_1 | Aug 17 09:29:06.250 [notice] Opening Socks listener on 127.0.0.1:9050
tor_server_1 | Aug 17 09:29:06.250 [notice] Opened Socks listener connection (ready) on 127.0.0.1:9050
tor_server_1 | Aug 17 09:29:06.000 [notice] Bootstrapped 0% (starting): Starting
tor_server_1 | Aug 17 09:29:06.000 [notice] Starting with guard context “default”
tor_server_1 | Aug 17 09:29:07.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor_server_1 | Aug 17 09:29:08.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor_server_1 | Aug 17 09:29:08.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor_server_1 | Aug 17 09:29:08.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor_server_1 | Aug 17 09:29:08.000 [notice] Bootstrapped 20% (onehop_create): Establishing an encrypted directory connection
tor_server_1 | Aug 17 09:29:09.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
tor_server_1 | Aug 17 09:29:09.000 [notice] Bootstrapped 30% (loading_status): Loading networkstatus consensus
tor_server_1 | Aug 17 09:29:11.000 [notice] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
tor_server_1 | Aug 17 09:29:11.000 [notice] Bootstrapped 40% (loading_keys): Loading authority key certs
tor_server_1 | Aug 17 09:29:12.000 [notice] The current consensus has no exit nodes. Tor can only build internal paths, such as paths to onion services.
tor_server_1 | Aug 17 09:29:12.000 [notice] Bootstrapped 45% (requesting_descriptors): Asking for relay descriptors
tor_server_1 | Aug 17 09:29:12.000 [notice] I learned some more directory information, but not enough to build a circuit: We need more microdescriptors: we have 0/6771, and can only build 0% of likely paths. (We have 0% of guards bw, 0% of midpoint bw, and 0% of end bw (no exits in consensus, using mid) = 0% of path bw.)
tor_server_1 | Aug 17 09:29:14.000 [notice] Bootstrapped 50% (loading_descriptors): Loading relay descriptors
tor_server_1 | Aug 17 09:29:16.000 [notice] The current consensus contains exit nodes. Tor can build exit and internal paths.
tor_server_1 | Aug 17 09:29:18.000 [notice] Bootstrapped 57% (loading_descriptors): Loading relay descriptors
tor_server_1 | Aug 17 09:29:18.000 [notice] Bootstrapped 63% (loading_descriptors): Loading relay descriptors
tor_server_1 | Aug 17 09:29:21.000 [notice] Bootstrapped 68% (loading_descriptors): Loading relay descriptors
tor_server_1 | Aug 17 09:29:22.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_server_1 | Aug 17 09:29:22.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_server_1 | Aug 17 09:29:22.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_server_1 | Aug 17 09:29:23.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_server_1 | Aug 17 09:29:24.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_server_1 | Aug 17 09:29:24.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_server_1 | Aug 17 09:29:25.000 [notice] Bootstrapped 100% (done): Done
lightning
tor_server_1 | Aug 17 09:30:31.581 [notice] Read configuration file “/etc/tor/torrc”.
tor_server_1 | Aug 17 09:30:31.651 [notice] Opening Socks listener on 127.0.0.1:9050
tor_server_1 | Aug 17 09:30:31.651 [notice] Opened Socks listener connection (ready) on 127.0.0.1:9050
tor_server_1 | Aug 17 09:30:31.000 [notice] Bootstrapped 0% (starting): Starting
tor_server_1 | Aug 17 09:30:31.000 [notice] Starting with guard context “default”
tor_server_1 | Aug 17 09:30:32.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor_server_1 | Aug 17 09:30:33.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor_server_1 | Aug 17 09:30:33.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor_server_1 | Aug 17 09:30:33.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor_server_1 | Aug 17 09:30:33.000 [notice] Bootstrapped 20% (onehop_create): Establishing an encrypted directory connection
tor_server_1 | Aug 17 09:30:33.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
tor_server_1 | Aug 17 09:30:34.000 [notice] Bootstrapped 30% (loading_status): Loading networkstatus consensus
tor_server_1 | Aug 17 09:30:36.000 [notice] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
tor_server_1 | Aug 17 09:30:36.000 [notice] Bootstrapped 40% (loading_keys): Loading authority key certs
tor_server_1 | Aug 17 09:30:37.000 [notice] The current consensus has no exit nodes. Tor can only build internal paths, such as paths to onion services.
tor_server_1 | Aug 17 09:30:37.000 [notice] Bootstrapped 45% (requesting_descriptors): Asking for relay descriptors
tor_server_1 | Aug 17 09:30:37.000 [notice] I learned some more directory information, but not enough to build a circuit: We need more microdescriptors: we have 0/6771, and can only build 0% of likely paths. (We have 0% of guards bw, 0% of midpoint bw, and 0% of end bw (no exits in consensus, using mid) = 0% of path bw.)
tor_server_1 | Aug 17 09:30:39.000 [notice] Bootstrapped 50% (loading_descriptors): Loading relay descriptors
tor_server_1 | Aug 17 09:30:40.000 [notice] I learned some more directory information, but not enough to build a circuit: We need more microdescriptors: we have 0/6771, and can only build 0% of likely paths. (We have 0% of guards bw, 0% of midpoint bw, and 0% of end bw (no exits in consensus, using mid) = 0% of path bw.)
tor_server_1 | Aug 17 09:30:43.000 [notice] The current consensus contains exit nodes. Tor can build exit and internal paths.
tor_server_1 | Aug 17 09:30:48.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_server_1 | Aug 17 09:30:49.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_server_1 | Aug 17 09:30:50.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_server_1 | Aug 17 09:30:50.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_server_1 | Aug 17 09:30:51.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_server_1 | Aug 17 09:30:51.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_server_1 | Aug 17 09:30:51.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_server_1 | Aug 17 09:30:51.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_server_1 | Aug 17 09:30:51.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_server_1 | Aug 17 09:30:52.000 [notice] Bootstrapped 100% (done): Done
==== Result ====
SOLVED.
Check out this note.
It seems that the issues are always with the updates. If an update fails, or has errors, it makes the dockers hang back.
hi - I am apparently hgaving same issues but different set up -
lost my A2F
so I reflashed sd card -Ok
I am re installing it to my pi
and loging into my umbrel.local I have same screen with …containers … stop same level!
The thing is I try to putty ssh - my password (old) is not giving me access sound logical - is there a defautl password for after reflashed??
maybe should i re format the HD as well ? and start again from the very beginning … :expressionless:
