Node Error EXCEPTION: 15dbwrapper_error on bitcoin
My node got error after the power went out while still syncing.
Anyone can help me?
Below is debug.
umbrel@umbrel:~ $ ./umbrel/scripts/debug --upload
0.3.14
Flashed OS version
v0.3.10
Raspberry Pi Model
Revision : c03112
Serial : 10000000aefa6319
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
Feb 25 2021 12:10:40
Copyright © 2012 Broadcom
version 564e5f9b852b23a330b1764bcf0b2d022a20afd0 (clean) (release) (start)
Temperature
temp=54.5’C
Throttling
throttled=0x0
Mem: 3.8G 915M 224M 5.0M 2.7G 3.1G
Swap: 4.1G 4.0M 4.1G
total: 24.1%
lnd: 9.5%
bitcoin: 9.5%
system: 4.1%
tor: 0.9%
electrs: 0.1%
Memory monitor logs
2021-07-12 19:22:07 Memory monitor running!
2021-07-28 14:03:14 Memory monitor running!
2021-07-29 12:47:44 Memory monitor running!
/dev/root 59G 2.8G 54G 5% /
/dev/sda1 458G 194G 241G 45% /home/umbrel/umbrel
Startup service logs
Jul 29 12:47:44 umbrel umbrel startup[1394]: Starting backup monitor…
Jul 29 12:47:44 umbrel umbrel startup[1394]: Starting decoy backup trigger…
Jul 29 12:47:44 umbrel umbrel startup[1394]: Starting Docker services…
Jul 29 12:47:46 umbrel umbrel startup[1394]: Creating network “umbrel_main_network” with the default driver
Jul 29 12:47:47 umbrel umbrel startup[1394]: Creating dashboard …
Jul 29 12:47:47 umbrel umbrel startup[1394]: Creating tor …
Jul 29 12:47:47 umbrel umbrel startup[1394]: Creating electrs …
Jul 29 12:47:51 umbrel umbrel startup[1394]: Creating electrs … done
Jul 29 12:47:51 umbrel umbrel startup[1394]: Creating dashboard … done
Jul 29 12:47:51 umbrel umbrel startup[1394]: Creating tor … done
Jul 29 12:47:51 umbrel umbrel startup[1394]: Creating manager …
Jul 29 12:48:12 umbrel umbrel startup[1394]: Creating manager … done
Jul 29 12:48:12 umbrel umbrel startup[1394]: Creating lnd …
Jul 29 12:48:12 umbrel umbrel startup[1394]: Creating nginx …
Jul 29 12:48:25 umbrel umbrel startup[1394]: Creating lnd … done
Jul 29 12:48:25 umbrel umbrel startup[1394]: Creating nginx … done
Jul 29 12:48:25 umbrel umbrel startup[1394]: Creating bitcoin …
Jul 29 12:48:29 umbrel umbrel startup[1394]: Creating bitcoin … done
Jul 29 12:48:29 umbrel umbrel startup[1394]: Creating neutrino-switcher …
Jul 29 12:48:29 umbrel umbrel startup[1394]: Creating middleware …
Jul 29 12:48:31 umbrel umbrel startup[1394]: Creating neutrino-switcher … done
Jul 29 12:48:33 umbrel umbrel startup[1394]: Creating middleware … done
Jul 29 12:48:33 umbrel umbrel startup[1394]: Removing status server iptables entry…
Jul 29 12:48:33 umbrel umbrel startup[1394]: Removed existing iptables entry.
Jul 29 12:48:33 umbrel umbrel startup[1394]: Starting installed apps…
Jul 29 12:48:33 umbrel umbrel startup[1394]: Umbrel is now accessible at
Jul 29 12:48:33 umbrel umbrel startup[1394]: http://umbrel.local
Jul 29 12:48:33 umbrel umbrel startup[1394]: http://192.168.68.115
Jul 29 12:48:33 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
– Logs begin at Thu 2021-07-29 12:47:20 UTC, end at Thu 2021-07-29 13:09:10 UTC. –
Jul 29 12:47:25 umbrel systemd[1]: Starting External Storage Mounter…
Jul 29 12:47:25 umbrel external storage mounter[478]: Running external storage mount script…
Jul 29 12:47:25 umbrel external storage mounter[478]: Found device “WD My Passport 0810”
Jul 29 12:47:25 umbrel external storage mounter[478]: Blacklisting USB device IDs against UAS driver…
Jul 29 12:47:25 umbrel external storage mounter[478]: Rebinding USB drivers…
Jul 29 12:47:26 umbrel external storage mounter[478]: Checking USB devices are back…
Jul 29 12:47:26 umbrel external storage mounter[478]: Waiting for USB devices…
Jul 29 12:47:27 umbrel external storage mounter[478]: Waiting for USB devices…
Jul 29 12:47:28 umbrel external storage mounter[478]: Checking if the device is ext4…
Jul 29 12:47:28 umbrel external storage mounter[478]: Yes, it is ext4
Jul 29 12:47:28 umbrel external storage mounter[478]: Checking if device contains an Umbrel install…
Jul 29 12:47:28 umbrel external storage mounter[478]: Yes, it contains an Umbrel install
Jul 29 12:47:28 umbrel external storage mounter[478]: Bind mounting external storage over local Umbrel installation…
Jul 29 12:47:28 umbrel external storage mounter[478]: Bind mounting external storage over local Docker data dir…
Jul 29 12:47:28 umbrel external storage mounter[478]: Bind mounting external storage to /swap
Jul 29 12:47:28 umbrel external storage mounter[478]: Bind mounting SD card root at /sd-card…
Jul 29 12:47:28 umbrel external storage mounter[478]: Checking Umbrel root is now on external storage…
Jul 29 12:47:29 umbrel external storage mounter[478]: Checking /var/lib/docker is now on external storage…
Jul 29 12:47:29 umbrel external storage mounter[478]: Checking /swap is now on external storage…
Jul 29 12:47:29 umbrel external storage mounter[478]: Setting up swapfile
Jul 29 12:47:33 umbrel external storage mounter[478]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jul 29 12:47:33 umbrel external storage mounter[478]: no label, UUID=1652125f-fa9c-4f6f-8ff8-ee40cf844633
Jul 29 12:47:33 umbrel external storage mounter[478]: Checking SD Card root is bind mounted at /sd-root…
Jul 29 12:47:33 umbrel external storage mounter[478]: Starting external drive mount monitor…
Jul 29 12:47:33 umbrel external storage mounter[478]: Mount script completed successfully!
Jul 29 12:47:33 umbrel systemd[1]: Started External Storage Mounter.
Jul 29 12:47:43 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jul 29 12:47:43 umbrel external storage updater[1316]: Checking if SD card Umbrel is newer than external storage…
Jul 29 12:47:43 umbrel external storage updater[1316]: No, SD version is not newer, exiting.
Jul 29 12:47:43 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Uploading backup…
100 3358 100 146 100 3212 19 420 0:00:07 0:00:07 --:–:-- 439
{“message”:“Successfully uploaded backup 1627449579045.tar.gz.pgp for backup ID 52ce0ccb8fd2cdc8936692f5b0aae16c97266c50c4ccc6023dd28ae5e98a11a8”}
====== Backup success =======
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
5003 bytes (5.0 kB, 4.9 KiB) copied, 0.000285368 s, 17.5 MB/s
Creating encrypted tarball…
backup/
backup/.padding
backup/channel.backup
Uploading backup…
100 5772 100 146 100 5626 50 1932 0:00:02 0:00:02 --:–:-- 1982
{“message”:“Successfully uploaded backup 1627519024290.tar.gz.pgp for backup ID 52ce0ccb8fd2cdc8936692f5b0aae16c97266c50c4ccc6023dd28ae5e98a11a8”}
Got signal: backup
Deriving keys…
Creating backup…
1+0 records in
1+0 records out
9175 bytes (9.2 kB, 9.0 KiB) copied, 0.000391441 s, 23.4 MB/s
backup/
backup/.padding
Uploading backup…
100 9983 100 146 100 9837 60 4058 0:00:02 0:00:02 --:–:-- 4118
{“message”:“Successfully uploaded backup 1627528575949.tar.gz.pgp for backup ID 52ce0ccb8fd2cdc8936692f5b0aae16c97266c50c4ccc6023dd28ae5e98a11a8”}
Docker containers
NAMES STATUS
middleware Up 20 minutes
neutrino-switcher Up 20 minutes
bitcoin Up 16 seconds
nginx Up 21 minutes
lnd Up 21 minutes
manager Up 21 minutes
electrs Up 42 seconds
tor Up 21 minutes
dashboard Up 21 minutes
Bitcoin Core logs
Attaching to bitcoin
bitcoin | 2021-07-29T13:09:11Z Using rpcauth authentication.
bitcoin | 2021-07-29T13:09:11Z HTTP: starting 4 worker threads
bitcoin | 2021-07-29T13:09:11Z Using wallet directory /data/.bitcoin
bitcoin | 2021-07-29T13:09:11Z init message: Verifying wallet(s)…
bitcoin | 2021-07-29T13:09:11Z init message: Loading banlist…
bitcoin | 2021-07-29T13:09:11Z SetNetworkActive: true
bitcoin | 2021-07-29T13:09:11Z Using /16 prefix for IP bucketing
bitcoin | 2021-07-29T13:09:11Z Cache configuration:
bitcoin | 2021-07-29T13:09:11Z * Using 2.0 MiB for block index database
bitcoin | 2021-07-29T13:09:11Z * Using 24.8 MiB for transaction index database
bitcoin | 2021-07-29T13:09:11Z * Using 21.7 MiB for basic block filter index database
bitcoin | 2021-07-29T13:09:11Z * Using 8.0 MiB for chain state database
bitcoin | 2021-07-29T13:09:11Z * Using 143.6 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
bitcoin | 2021-07-29T13:09:11Z init message: Loading block index…
bitcoin | 2021-07-29T13:09:11Z Switching active chainstate to Chainstate [ibd] @ height -1 (null)
bitcoin | 2021-07-29T13:09:11Z Opening LevelDB in /data/.bitcoin/blocks/index
bitcoin | 2021-07-29T13:09:12Z Opened LevelDB successfully
bitcoin | 2021-07-29T13:09:12Z Using obfuscation key for /data/.bitcoin/blocks/index: 0000000000000000
bitcoin | 2021-07-29T13:09:25Z LoadBlockIndexDB: last block file = 1186
bitcoin | 2021-07-29T13:09:25Z LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=56, size=55942574, heights=509277…510298, time=2018-02-15…2018-02-21)
bitcoin | 2021-07-29T13:09:25Z Checking all blk files are present…
bitcoin | 2021-07-29T13:09:25Z Opening LevelDB in /data/.bitcoin/chainstate
bitcoin | 2021-07-29T13:09:25Z Opened LevelDB successfully
bitcoin | 2021-07-29T13:09:25Z Using obfuscation key for /data/.bitcoin/chainstate: 871e45004ced7d9e
bitcoin | 2021-07-29T13:09:26Z Loaded best chain: hashBestChain=00000000000000000053014b48f27e923f4db9244d951ec4266ffb4c3383c7dc height=508990 date=2018-02-13T12:02:02Z progress=0.450081
bitcoin | 2021-07-29T13:09:26Z init message: Rewinding blocks…
bitcoin | 2021-07-29T13:09:28Z FlushStateToDisk: write coins cache to disk (0 coins, 0kB) started
bitcoin | 2021-07-29T13:09:28Z FlushStateToDisk: write coins cache to disk (0 coins, 0kB) completed (0.00s)
bitcoin | 2021-07-29T13:09:28Z init message: Verifying blocks…
bitcoin | 2021-07-29T13:09:28Z Verifying last 6 blocks at level 3
LND logs
Attaching to lnd
lnd | 2021-07-29 13:01:38.104 [INF] BTCN: Lost peer 146.168.100.58:8333 (outbound)
lnd | 2021-07-29 13:01:38.105 [INF] BTCN: Syncing to block height 693224 from peer 217.123.41.222:8333
lnd | 2021-07-29 13:01:38.105 [INF] BTCN: Fetching set of headers from tip (height=693224) from peer 217.123.41.222:8333
lnd | 2021-07-29 13:01:39.804 [WRN] BTCN: Banning peer 52.11.1.128:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-07-29 13:01:39.808 [INF] BTCN: Lost peer 52.11.1.128:8333 (outbound)
lnd | 2021-07-29 13:01:41.293 [INF] BTCN: Lost peer 84.75.253.40:8333 (outbound)
lnd | 2021-07-29 13:01:41.441 [INF] BTCN: New valid peer 81.169.179.225:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:01:42.639 [INF] BTCN: New valid peer 89.161.26.78:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:03:01.214 [INF] BTCN: Lost peer 178.13.29.176:8333 (outbound)
lnd | 2021-07-29 13:03:04.456 [WRN] BTCN: Banning peer 173.51.177.2:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-07-29 13:03:04.459 [INF] BTCN: Lost peer 173.51.177.2:8333 (outbound)
lnd | 2021-07-29 13:03:05.397 [INF] BTCN: Lost peer 5.2.67.72:8333 (outbound)
lnd | 2021-07-29 13:03:05.905 [INF] BTCN: New valid peer 87.121.37.156:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:03:06.545 [INF] BTCN: New valid peer 95.80.10.185:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:03:08.994 [INF] BTCN: Lost peer 95.80.10.185:8333 (outbound)
lnd | 2021-07-29 13:03:54.081 [INF] BTCN: New valid peer 80.218.199.202:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:03:54.519 [INF] BTCN: Lost peer 80.218.199.202:8333 (outbound)
lnd | 2021-07-29 13:04:06.164 [INF] BTCN: New valid peer 207.253.27.72:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:04:07.515 [INF] BTCN: Lost peer 207.253.27.72:8333 (outbound)
lnd | 2021-07-29 13:04:10.527 [INF] BTCN: New valid peer 144.2.69.69:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:04:10.827 [INF] BTCN: Lost peer 144.2.69.69:8333 (outbound)
lnd | 2021-07-29 13:06:04.125 [INF] BTCN: Lost peer 89.161.26.78:8333 (outbound)
lnd | 2021-07-29 13:06:05.876 [INF] BTCN: New valid peer 37.48.67.11:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:06:23.088 [INF] BTCN: New valid peer 74.101.121.94:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:06:26.304 [INF] BTCN: Lost peer 74.101.121.94:8333 (outbound)
lnd | 2021-07-29 13:07:14.518 [INF] BTCN: New valid peer 88.207.241.118:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-07-29 13:07:18.873 [INF] BTCN: Lost peer 88.207.241.118:8333 (outbound)
lnd | 2021-07-29 13:07:22.314 [INF] BTCN: New valid peer 195.201.95.119:8333 (outbound) (/Satoshi:0.20.99/)
lnd | 2021-07-29 13:08:31.730 [ERR] BTCN: Unable to parse IP network for peer my43c4fiiqqqusc2.onion:8333: unsupported IP type
lnd | 2021-07-29 13:08:41.787 [INF] BTCN: New valid peer 91.134.145.202:8333 (outbound) (/Satoshi:0.21.1/)
Tor logs
Attaching to tor
tor | Jul 29 13:03:59.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $E321D0118DAD44BBC74A5C26FE7CFDBAAF3DA077~relayon0112 [fnvU42jW046jrFV4U0fpZDQ9z3w0/JjTlBDytlNnO7A] at 185.220.101.2. Retrying on a new circuit.
tor | Jul 29 13:04:14.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $555A6B7CB3D8ECA376B4CB6701596A7B211E21D3~Quetzalcoatl [4uSS7eewaXLVg0Abxn6YQoAFFDetFl16HTrMNMbFiXc] at 45.61.185.125. Retrying on a new circuit.
tor | Jul 29 13:04:29.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $CD09CD7C7F8815B37210C7D1A628599C78D22D6D~niftyeltab [+9oNhM3zrYGkR5B4XyZiGx5FgH+2Y3BmSGPcxv59iUI] at 185.220.100.249. Retrying on a new circuit.
tor | Jul 29 13:04:44.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $98F793C7320CE3C15A45353AFCC165747A40366D~F3Netze [sSWyZJ/Ab5YjRO5R7Hh0v3/27BvIn4FXHsHgfMP8s0Q] at 185.220.100.255. Retrying on a new circuit.
tor | Jul 29 13:04:45.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $98F793C7320CE3C15A45353AFCC165747A40366D~F3Netze [sSWyZJ/Ab5YjRO5R7Hh0v3/27BvIn4FXHsHgfMP8s0Q] at 185.220.100.255. Retrying on a new circuit.
tor | Jul 29 13:04:59.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $CD09CD7C7F8815B37210C7D1A628599C78D22D6D~niftyeltab [+9oNhM3zrYGkR5B4XyZiGx5FgH+2Y3BmSGPcxv59iUI] at 185.220.100.249. Retrying on a new circuit.
tor | Jul 29 13:05:00.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $CD09CD7C7F8815B37210C7D1A628599C78D22D6D~niftyeltab [+9oNhM3zrYGkR5B4XyZiGx5FgH+2Y3BmSGPcxv59iUI] at 185.220.100.249. Retrying on a new circuit.
tor | Jul 29 13:05:19.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $3C89C80E2699FB6358BBB64FDC9547AFCB5C03F7~F3Netze [l1jD02S9qTqbElak0IR7Ea+Ov+bvuagFT8G53EVDbDY] at 185.220.100.240. Retrying on a new circuit.
tor | Jul 29 13:05:34.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $13FB26F9361F803AD190FE88B35E241DC084B026~Digitalcourage4ipgb [UGC3pSUMgfq92TUm1A0+dyOYcj/KtEJFow39Oj8XllE] at 185.220.102.246. Retrying on a new circuit.
tor | Jul 29 13:05:39.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $FDA70EC93DB01E3CB418CB6943B0C68464B18B4C~relayon0134 [7BE4DvrOw45UW59XblFJCvm/kNVxiRcGbQg66Oj53Q0] at 185.220.101.5. Retrying on a new circuit.
tor | Jul 29 13:05:49.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $FDA70EC93DB01E3CB418CB6943B0C68464B18B4C~relayon0134 [7BE4DvrOw45UW59XblFJCvm/kNVxiRcGbQg66Oj53Q0] at 185.220.101.5. Retrying on a new circuit.
tor | Jul 29 13:05:57.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $F475E5987E44A2B7B143A2BEE3F8128EEFD7E5A3~0x1ea7deadbeef [9pYJ3jnLgOJB63cT9s4fNjaTTQcRvv1KEHLKVoTLOGk] at 188.68.45.180. Retrying on a new circuit.
tor | Jul 29 13:06:04.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $F475E5987E44A2B7B143A2BEE3F8128EEFD7E5A3~0x1ea7deadbeef [9pYJ3jnLgOJB63cT9s4fNjaTTQcRvv1KEHLKVoTLOGk] at 188.68.45.180. Retrying on a new circuit.
tor | Jul 29 13:06:06.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | Jul 29 13:06:12.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $9425164E47E7B8F2AA66944FBDC38CFAFB3E0B7C~AutomaticArrestLine [zkdoGU4xTT8p65mDt+FjFzllTj7aqKhSA73qWMqjC0o] at 23.129.64.136. Retrying on a new circuit.
tor | Jul 29 13:06:19.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $9425164E47E7B8F2AA66944FBDC38CFAFB3E0B7C~AutomaticArrestLine [zkdoGU4xTT8p65mDt+FjFzllTj7aqKhSA73qWMqjC0o] at 23.129.64.136. Retrying on a new circuit.
tor | Jul 29 13:06:19.000 [notice] Tried for 129 seconds to get a connection to [scrubbed]:8333. Giving up.
tor | Jul 29 13:06:27.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $DA328B3B5B6CB91D173EB31F73086183EB8DE8CB~uwumiao [/dO++McZ+Shd5IZUuRptEBBGE1CfNUMCJ53Cpti3DKM] at 91.149.225.131. Retrying on a new circuit.
tor | Jul 29 13:06:42.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $FDA70EC93DB01E3CB418CB6943B0C68464B18B4C~relayon0134 [7BE4DvrOw45UW59XblFJCvm/kNVxiRcGbQg66Oj53Q0] at 185.220.101.5. Retrying on a new circuit.
tor | Jul 29 13:06:57.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $DD8BD7307017407FCC36F8D04A688F74A0774C02~DFRI0 [3YzQBY0tjBYayCeyPJVGtw3sG7D1YSxXI3Gn0QfJeFw] at 171.25.193.20. Retrying on a new circuit.
tor | Jul 29 13:07:01.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $DD8BD7307017407FCC36F8D04A688F74A0774C02~DFRI0 [3YzQBY0tjBYayCeyPJVGtw3sG7D1YSxXI3Gn0QfJeFw] at 171.25.193.20. Retrying on a new circuit.
tor | Jul 29 13:07:12.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $953961E3323F9507390BEBA6EFA5FD62BCE7020E~unimatrix001 [WdaAiy750dupf876wC/Y5km/mftSERONWP6cBXU5rDI] at 23.236.146.162. Retrying on a new circuit.
tor | Jul 29 13:07:12.000 [notice] Tried for 128 seconds to get a connection to [scrubbed]:8333. Giving up.
tor | Jul 29 13:07:16.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $953961E3323F9507390BEBA6EFA5FD62BCE7020E~unimatrix001 [WdaAiy750dupf876wC/Y5km/mftSERONWP6cBXU5rDI] at 23.236.146.162. Retrying on a new circuit.
tor | Jul 29 13:07:31.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $FC8AF7017E12322EF84CEA7405D928B2D5B19ED0~namedrelay [btO3ep5Lxgo6uetB9fmvMYjX0+U55p5laixq7/wIsSY] at 143.198.101.130. Retrying on a new circuit.
tor | Jul 29 13:07:46.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $9971F51A3274758B5C59E1D6580ED2C13E13CBEC~F3Netze [cggwXqDgzCUQesXEApe+afP4rY5p1RJBS4qTC11LMdo] at 185.220.100.254. Retrying on a new circuit.
tor | Jul 29 13:08:01.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $721E494B0E06554D8F9A169BDBF17282C07B2588~desync [wWlbnFHcdXExytFdI5cCNXFErLzZS527T8x8k2b5bvA] at 66.230.230.230. Retrying on a new circuit.
tor | Jul 29 13:08:16.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $B2002D5C75A0FAD8F33962614718F35CB672CC57~relayon0107 [tDekXu6nB8wcgAdtAhBoM1APpoY8WahgfcSV6slZ1RE] at 185.220.101.8. Retrying on a new circuit.
tor | Jul 29 13:08:31.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $C0833D395E81F19EC5F3BBC60D89470BE2F15199~PhantomFreak [xoQAJnrdunR4O4lHOg9kp19QwU462SLj7Z4V47TW/pM] at 23.129.64.160. Retrying on a new circuit.
tor | Jul 29 13:08:31.000 [notice] Tried for 125 seconds to get a connection to [scrubbed]:8333. Giving up.
==== Result ====
Please share the following links and paste it in the Umbrel Telegram group (https://t.me/getumbrel) so we can help you with your problem.
https://umbrel-paste.vercel.app/
And this is also the log from ~/umbrel/bitcoin/debug.log.
Fatal LevelDB error: Corruption: block checksum mismatch: /data/.bitcoin/indexes/txindex/150929.ldb
bitcoin in scheduler
2021-07-29T13:14:40Z Bitcoin Core version v0.21.1.0-g194b9b8792d9b0798fdb570b79fa51f1d1f5ebaf (release build)
2021-07-29T13:14:40Z InitParameterInteraction: parameter interaction: -proxy set -> setting -upnp=0
2021-07-29T13:14:40Z InitParameterInteraction: parameter interaction: -proxy set -> setting -discover=0
2021-07-29T13:14:40Z Assuming ancestors of block 0000000000000000000b9d2ec5a352ecba0592946514a92f14319dc2b367fc72 have valid signatures.
2021-07-29T13:14:40Z Setting nMinimumChainWork=00000000000000000000000000000000000000001533efd8d716a517fe2c5008
2021-07-29T13:14:40Z Using the ‘standard’ SHA256 implementation
2021-07-29T13:14:40Z Default data directory /data/.bitcoin
2021-07-29T13:14:40Z Using data directory /data/.bitcoin
2021-07-29T13:14:40Z Config file: /data/.bitcoin/bitcoin.conf
2021-07-29T13:14:40Z Config file arg: bind=“10.21.21.8”
2021-07-29T13:14:40Z Config file arg: blockfilterindex=“1”
2021-07-29T13:14:40Z Config file arg: dbcache=“200”
2021-07-29T13:14:40Z Config file arg: listen=“1”
2021-07-29T13:14:40Z Config file arg: maxmempool=“300”
2021-07-29T13:14:40Z Config file arg: peerblockfilters=“1”
2021-07-29T13:14:40Z Config file arg: peerbloomfilters=“1”
2021-07-29T13:14:40Z Config file arg: port=“8333”
2021-07-29T13:14:40Z Config file arg: proxy=“10.21.21.11:9050”
2021-07-29T13:14:40Z Config file arg: rpcallowip=“10.21.21.1/16”
2021-07-29T13:14:40Z Config file arg: rpcallowip=“127.0.0.1”
2021-07-29T13:14:40Z Config file arg: rpcauth=****
2021-07-29T13:14:40Z Config file arg: rpcbind=****
2021-07-29T13:14:40Z Config file arg: rpcport=“8332”
2021-07-29T13:14:40Z Config file arg: txindex=“1”
2021-07-29T13:14:40Z Config file arg: zmqpubhashblock=“tcp://0.0.0.0:28334”
2021-07-29T13:14:40Z Config file arg: zmqpubrawblock=“tcp://0.0.0.0:28332”
2021-07-29T13:14:40Z Config file arg: zmqpubrawtx=“tcp://0.0.0.0:28333”
2021-07-29T13:14:40Z Command-line arg: zmqpubrawblock=“tcp://0.0.0.0:28332”
2021-07-29T13:14:40Z Command-line arg: zmqpubrawtx=“tcp://0.0.0.0:28333”
2021-07-29T13:14:40Z Using at most 125 automatic connections (1048576 file descriptors available)
2021-07-29T13:14:40Z Using 16 MiB out of 32/2 requested for signature cache, able to store 524288 elements
2021-07-29T13:14:40Z Using 16 MiB out of 32/2 requested for script execution cache, able to store 524288 elements
2021-07-29T13:14:40Z Script verification uses 3 additional threads
2021-07-29T13:14:40Z scheduler thread start
2021-07-29T13:14:40Z HTTP: creating work queue of depth 16
2021-07-29T13:14:40Z Using random cookie authentication.
2021-07-29T13:14:40Z Generated RPC authentication cookie /data/.bitcoin/.cookie
2021-07-29T13:14:40Z Using rpcauth authentication.
2021-07-29T13:14:40Z HTTP: starting 4 worker threads
2021-07-29T13:14:40Z Using wallet directory /data/.bitcoin
2021-07-29T13:14:40Z init message: Verifying wallet(s)…
2021-07-29T13:14:40Z init message: Loading banlist…
2021-07-29T13:14:40Z SetNetworkActive: true
2021-07-29T13:14:40Z Using /16 prefix for IP bucketing
2021-07-29T13:14:40Z Cache configuration:
2021-07-29T13:14:40Z * Using 2.0 MiB for block index database
2021-07-29T13:14:40Z * Using 24.8 MiB for transaction index database
2021-07-29T13:14:40Z * Using 21.7 MiB for basic block filter index database
2021-07-29T13:14:40Z * Using 8.0 MiB for chain state database
2021-07-29T13:14:40Z * Using 143.6 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
2021-07-29T13:14:40Z init message: Loading block index…
2021-07-29T13:14:40Z Switching active chainstate to Chainstate [ibd] @ height -1 (null)
2021-07-29T13:14:40Z Opening LevelDB in /data/.bitcoin/blocks/index
2021-07-29T13:14:42Z Opened LevelDB successfully
2021-07-29T13:14:42Z Using obfuscation key for /data/.bitcoin/blocks/index: 0000000000000000
2021-07-29T13:14:55Z LoadBlockIndexDB: last block file = 1186
2021-07-29T13:14:55Z LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=56, size=55942574, heights=509277…510298, time=2018-02-15…2018-02-21)
2021-07-29T13:14:55Z Checking all blk files are present…
2021-07-29T13:14:55Z Opening LevelDB in /data/.bitcoin/chainstate
2021-07-29T13:14:55Z Opened LevelDB successfully
2021-07-29T13:14:55Z Using obfuscation key for /data/.bitcoin/chainstate: 871e45004ced7d9e
2021-07-29T13:14:56Z Loaded best chain: hashBestChain=00000000000000000053014b48f27e923f4db9244d951ec4266ffb4c3383c7dc height=508990 date=2018-02-13T12:02:02Z progress=0.450081
2021-07-29T13:14:56Z init message: Rewinding blocks…
2021-07-29T13:14:58Z FlushStateToDisk: write coins cache to disk (0 coins, 0kB) started
2021-07-29T13:14:58Z FlushStateToDisk: write coins cache to disk (0 coins, 0kB) completed (0.00s)
2021-07-29T13:14:58Z init message: Verifying blocks…
2021-07-29T13:14:58Z Verifying last 6 blocks at level 3
2021-07-29T13:14:58Z [0%]…[16%]…[33%]…[50%]…[66%]…[83%]…[99%]…[DONE].
2021-07-29T13:15:01Z No coin database inconsistencies in last 6 blocks (3876 transactions)
2021-07-29T13:15:01Z block index 20980ms
2021-07-29T13:15:01Z Opening LevelDB in /data/.bitcoin/indexes/txindex
2021-07-29T13:15:01Z Opened LevelDB successfully
2021-07-29T13:15:01Z Using obfuscation key for /data/.bitcoin/indexes/txindex: 0000000000000000
2021-07-29T13:15:01Z txindex thread start
2021-07-29T13:15:01Z txindex is enabled at height 508990
2021-07-29T13:15:01Z txindex thread exit
2021-07-29T13:15:01Z Opening LevelDB in /data/.bitcoin/indexes/blockfilter/basic/db
2021-07-29T13:15:01Z Using obfuscation key for /data/.bitcoin/indexes/blockfilter/basic/db: 0000000000000000
2021-07-29T13:15:01Z basic block filter index thread start
2021-07-29T13:15:01Z basic block filter index is enabled at height 508990
2021-07-29T13:15:01Z basic block filter index thread exit
2021-07-29T13:15:01Z block tree size = 693081
2021-07-29T13:15:01Z nBestHeight = 508990
2021-07-29T13:15:01Z loadblk thread start
2021-07-29T13:15:01Z torcontrol thread start
2021-07-29T13:15:01Z Bound to 10.21.21.8:8333
2021-07-29T13:15:01Z Bound to 127.0.0.1:8334
2021-07-29T13:15:01Z init message: Loading P2P addresses…
2021-07-29T13:15:02Z UpdateTip: new best=0000000000000000002daf79ab2b854acc138ab0aa2cbc07ca80166b6fbf36b0 height=508991 version=0x20000000 log2_work=88.114151 tx=299207373 date=‘2018-02-13T12:03:07Z’ progress=0.450081 cache=0.9MiB(7071txo)
2021-07-29T13:15:02Z Loaded 65735 addresses from peers.dat 768ms
2021-07-29T13:15:02Z ERROR: DeserializeFileDB: Failed to open file /data/.bitcoin/anchors.dat
2021-07-29T13:15:02Z 0 block-relay-only anchors will be tried for connections.
2021-07-29T13:15:02Z init message: Starting network threads…
2021-07-29T13:15:02Z net thread start
2021-07-29T13:15:02Z addcon thread start
2021-07-29T13:15:02Z init message: Done loading
2021-07-29T13:15:02Z msghand thread start
2021-07-29T13:15:02Z dnsseed thread start
2021-07-29T13:15:02Z opencon thread start
2021-07-29T13:15:02Z Waiting 300 seconds before querying DNS seeds.
2021-07-29T13:15:02Z UpdateTip: new best=0000000000000000001153fbfa2c1ac7c7e5a2c5d1654fd2e3a5e22cab6e329f height=508992 version=0x20000000 log2_work=88.114204 tx=299207643 date=‘2018-02-13T12:04:24Z’ progress=0.450081 cache=1.8MiB(14144txo)
2021-07-29T13:15:03Z UpdateTip: new best=00000000000000000041497a899e3a5d275fe760776d8c59331b14d8f3454ff7 height=508993 version=0x20000000 log2_work=88.114258 tx=299208312 date=‘2018-02-13T12:09:12Z’ progress=0.450082 cache=2.9MiB(22162txo)
2021-07-29T13:15:03Z UpdateTip: new best=00000000000000000025d137b5f8f2f6bdb8e2bdca6e2553c82fd99817407aad height=508994 version=0x20000000 log2_work=88.114311 tx=299210611 date=‘2018-02-13T12:29:00Z’ progress=0.450086 cache=4.4MiB(31821txo)
2021-07-29T13:15:04Z UpdateTip: new best=0000000000000000003eb9999abb46205ec1199dd30187e82118681e2250ff54 height=508995 version=0x20000000 log2_work=88.114364 tx=299213222 date=‘2018-02-13T13:15:37Z’ progress=0.450090 cache=5.6MiB(41554txo)
2021-07-29T13:15:04Z UpdateTip: new best=0000000000000000003f274bfac1acc8d6818f856fafd7d8e0080b09e8b3572f height=508996 version=0x20000000 log2_work=88.114417 tx=299214397 date=‘2018-02-13T13:19:27Z’ progress=0.450092 cache=6.2MiB(46648txo)
2021-07-29T13:15:04Z Fatal LevelDB error: Corruption: block checksum mismatch: /data/.bitcoin/indexes/txindex/150929.ldb
2021-07-29T13:15:04Z You can use -debug=leveldb to get more complete diagnostic messages
