Hello, i have my nodes since several month now, it worked fine. I checked recently and see that the node doesn’t sync anymore, now i’m a 99.47% ( i was at 100% few weeks ago). i’m on a raspberry 4 with a SSD. I restarted the Raspberry but the problem is still here.
Try to update to LND 0.15.2 or higher. This is an emergency hot fix release to fix a bug that can cause lnd nodes to be unable to parse certain large blocks.
