After updating from Umbrel 1.1 my node (laptop with native install of Umbrel OS) did the restart but then got a failed boot because the mount of the HDD took more than 3 minutes (it takes 5 to succeed), which then took me into the emergency mode, but again, as I reported in a previous post, Umbrel auto locks the root user, so I end up in an endless loop without being able to troubleshoot.
I reported about this bug in this post:
So what happened is that I had to use a live USB to get into chroot, reset the root password again, and then when I restarted the HDD with Umbrel, it booted to the previous 1.1 version successfully. I’m guessing that it keeps the old version in case of failure? I can’t tell because even the journalctl logs don’t show the previous failed boot. It’s as if it never happened.
So:
Please fix the Umbrel release so it doesn’t lock the root user, and add more time for the system to mount the HDD (10 mins is enough, 3 is not).
How is it that I don’t see the effect of the update anywhere?
Another way, if your first unbootable UmbrelOS (sda) is in a VM, stop the VM, add a disk of 32GB, install the iso of UmbrelOS (1.5 now) on the second disk not the first unbootable one (in order to keep the blockchain). Until the new UmbrelOS is installed on the second disk (sdb).
Mount the /dev/sda3 (/data) of the first unbootable disk
Change/correct the bad /etc/fstab
Stop the VM
Delete the new disk and verify if the first one is now booting after correcting its bad /etc/fstab
