Hi, I have a known issue while updating my apps on umbrel home OS 1.2.2 which caused the freezing of all apps “not running”. I have tried to get support directly with umbrel (chat), mail and twitter. No response at all. Think i should move back to my simple Bitcoin core setup as I had no issues running my own node
If I look at the issues and response in this community, it seems that umbrel is dead. No support and help. Will never recommend using your service again
I had the same issue with absolutely no support. I ended up reflashing my Umbrel Home and starting over from scratch.
Could you explain how you have reflashed you umbrel home?
Hi, sorry to hear about the issues you’ve experienced with updating to Umbrel Home OS 1.2.2. The Umbrel team usually responds to inquiries, but it can sometimes take a little while as they’re often very busy. However, this forum is almost always a great place to get help, and the community is super active.
Have you already checked the FAQ? Many common issues are documented there, and you can often find quick workarounds. If that doesn’t help, feel free to share the details of your problem here – I’m sure we can find a solution together!
It’s very rare for such problems to occur. With a bit of patience, we’ll definitely figure this out so you can continue enjoying all the benefits of Umbrel. ![]()
Here is a step-by-step explanation of how to reset your Umbrel Home:
However, this is always the last resort. I recommend taking a close look at the FAQs beforehand.
