Nextcloud - how to set up OPcache?
do you know how to set up OPCache for nextcloud installed on Umbrel OS ?
You can try:
sudo nano ./umbrel/app-data/nextcloud/data/nextcloud/3rdparty/aws/aws-crt-php/php.ini
I think you can make appropriate configurations in the php.ini file. But I am not sure.
