Nextcloud, occ can't find php
Hy umbrel community
I upgraded Nextcloud to version 25.0.1 on Umbrel version 0.5.3 on a RaspberryPi.
On the Nextcloud configuration page it gives me the advise to run occ db:add-missing-indices to generate some missing indexes.
I did ssh on to umbrel an used the command
sudo -u www-data php occ db:add-missing-indices
and it gives me following error:
umbrel@umbrel:/ $ sudo -u www-data php occ db:add-missing-indices
sudo: php: command not found
umbrel@umbrel:/ $
It looks like it can’t find php.
How can I fix that?
Thanks for your help
I found the solution. Aftrer executing
sudo docker exec -u www-data -it nextcloud_web_1 php occ db:add-missing-indices
occ build the indices successfuly.
