Migrating from PI to Unix Machine
I want to explore migration from the PI to a bigger machine, now that Umbrel 0.5 supports easy install. I assume this should be something along the lines:
  • Set up new Umbrel on Unix machine
  • Shut down both nodes
  • Copy some folders from the original node’s SSD to the new node’s SSD
  • Start the new node
My question is what folders should be copied in the step 3. Or maybe I have missed some steps?
