Manually update lnd
Hello,
So I just saw there was a critical issue with LND and users have to upgrade it…
My problem here is i still run an old version of umbrel (pre v5) and it seems lnd is now failing to connect to the server: “server is still in the process of starting”
Is there a command I can use to upgrade LND without upgrading umbrel?
Many thanks.
I think the easier thing you can do is to upgrade to the latest version of umbrel, has been tested and look’s stable
was in the same shoes. i had 0.4.17 and was happy as a clam. someone broke LND, forcing me to update to 0.4.18, and then to 0.5.0…still stuck with pulling new containers during v5 update…
Log?
