LND Clearnet - externalip?
Hi everyone,
running LND in default Hybrid mode I don’t see my node advertised on clearnet though (e.g. amboss). As far as I understand the IP (and yes, I have a static IP) has to be advertised by setting “externalip” in lnd.conf. Here on umbrel1.4.2 I can only see a umbrel-lnd.conf and every direct edit is being overwritten by the GUI again as it seems. And in the GUI externalip is not whitelisted.
Port forwarding on the router is active btw.
Am I wrong? What am I missing?
Thanks for your input!
D.
Situation resolved. By setting up tunnelsats I have found out that umbrel needs to be restarted completely in order to have lnd.conf merged into umbrel-lnd.conf. And on the way I have learnt how to run tunnelsats successfully on umbrel home 1.4.2.
