LND Channels not connecting after reboot
I think at this point I would prefer to just force close all channels. Can you please instruct me how to do this safely? Thank you.
If you are 100% sure, yes, this could be the last resort.
Use this guide, option 3
Read carefully the steps.
And don’t restore your new umbrel node with the same seed. Just create a new fresh instance. Later you can send the recovered funds to your new node, or just use them in blixt as a companion node. Blixt is a mobile node.
Ok good to know. Maybe I will try a few more things first as a full restore seems risky. I am seeing this repeated error in the LND log. Does this shed any light?
'[ERR] LTND: unable to create partial chain control: status code: 401, response:"
Thanks for your continued assistance.
See below:
2022-03-03 19:13:49.725 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-03 19:13:49.783 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-03 19:13:50.288 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-03 19:13:52.757 [INF] LNWL: Opened wallet
2022-03-03 19:13:53.074 [INF] CHRE: Primary chain is set to: bitcoin
2022-03-03 19:13:53.357 [ERR] LTND: unable to create partial chain control: status code: 401, response: “”
2022-03-03 19:13:53.357 [ERR] LTND: Shutting down because error in main method: error creating wallet config: unable to create partial chain control: status code: 401, response: “”
2022-03-03 19:13:53.617 [INF] LTND: Shutdown complete
2022-03-03 19:13:55.155 [INF] LTND: Version: 0.14.2-beta commit=v0.14.2-beta, build=production, logging=default, debuglevel=info
2022-03-03 19:13:55.155 [INF] LTND: Active chain: Bitcoin (network=mainnet)
2022-03-03 19:13:55.158 [INF] RPCS: RPC server listening on 0.0.0.0:10009
2022-03-03 19:13:55.162 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
2022-03-03 19:13:55.162 [INF] LTND: Opening the main database, this might take a few minutes…
2022-03-03 19:13:55.162 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
2022-03-03 19:13:59.733 [ERR] RPCS: [/lnrpc.Lightning/WalletBalance]: waiting to start, RPC services not available
2022-03-03 19:13:59.736 [ERR] RPCS: [/lnrpc.Lightning/GetTransactions]: waiting to start, RPC services not available
could be data corruption, I don’t know.
start the recovery of funds in blixt and wipe the data. Start fresh.
Can you let me know how you resolved this issue? Did you get your funds back?
