fil
March 23, 2024, 3:46pm
1
Hi, what is the new way of putting in LNCLI commands. The old way with Terminal/SSH and
~/umbrel/scripts/app docker compose lightning exec lnd lncli …
no longer works with v.1.0.2.
I get:
This script requires “docker-compose” to be installed
Any advice? Thank you.
mayank
March 23, 2024, 4:26pm
2
Hey @fil . On umbrelOS 1.0, lncli can be used with:
sudo docker exec -it lightning_lnd_1 lncli
And bitcoin-cli can be used with:
sudo docker exec -it bitcoin_bitcoind_1 bitcoin-cli
fil
March 23, 2024, 4:56pm
3
Hey, @mayank . Thank you. I’ve tried that but I get:
umbrel@umbrel:~$ sudo docker exec -it lightning_lnd_1 lncli
[sudo] password for umbrel:
OCI runtime exec failed: exec failed: unable to start container process: open /dev/ptmx: no such device: unknown
Any suggestion how to fix this? Thank you.
tgm3d
April 17, 2024, 8:18pm
4
I have the same error message. Can’t get to lncli, but have a hanging transaction. Isn’t there a solution to get to command for such important things? (i use 1.04)
tgm3d
April 17, 2024, 9:47pm
5
ok, the solution was 1.1 Update.
sudo docker exec -it CONTAINERID lncli state
get Concainer ID : sudo docker ps : search for lightninglabs/lnd:v0.17.4-beta
the Container ID is after every Update new!
