LNBits - Unable to install extensions
when I log in using the AdminURL I see “manage extensions”, but no extensions are displayed. What can I do?
Umbrel: 0.5.4 / LNBits: 0.10.6
There seems to be some extra instructions in the Umbrel appstore for LNBits- does this help?
Yes, I followed the instructions and logged into the “Super Admin page”. But no extensions are shown.
Sorry mate, not sure then.
Outside of the above, all I can recommend is the classic IT fixes if you haven’t tried them.
Cmd + Shift + R or Ctrl + F5 for a hard-refresh
or even
sudo ./scripts/app update lnbits
Hi guys, I am having hard time login in as admin. Trying to do the above but no luck. Could you please update how to do this with the latest version? I see nowhere I can find this admin default password.
