On a fully operational LnBits installation are all extension gone and it’s also not possible to install any new extensions.
I don’t know when that actually happened. The last update was for the Lightning node.
The issue persists also after umbrel has been rebooted.
Any suggestions?
Thanks.
Redin
2
Yes. You nedd read carefully the instrutions on http://umbrel.local/app-store/lnbits to recover all your extensions.
It worked perfectly. Thanks a lot for your hint!
What’s the magic secret to fix this?
I went to the server admin page, saved.
Still nothing.
rene
5
Same here: the “Manage extensions” field is empty…
rene
6
do you have any ideas? Do I have to wait for an update?
