Does anyone have advice on how to upgrade to umbrelOS 1.0 on a linux laptop that is currently running .54 on an external drive? I can’t install the node on the internal drive because it’s only 256gb.
install the new update to your internal drive, then inside settings-advanced settings you will find a way to open terminal and follow this:
How to run Umbrel apps from an external disk - Guides - Umbrel Community
That’s an interesting approach and i could see that working if i wanted to do a fresh install of umbrel 1.0 instead of the upgrade because i could leave the blockchain on the external drive then point to it.
But will this approach work for a migration/upgrade from umbrel .54?
