Umbrel home not offering 1.0 upgrade
I Migrated a RPi node (4GB + 1TB SSD) to my new Umbrel home.
This failed twice, but succeeded third time.
However, it is stuck on umbrelOS Version 0.5.4 and doesn’t offer me the 1.0 upgrade.
I also cannot install new apps as they are stuck in “Installing” mode for ever.
Advice please.
Thanks
Mike
Hey Mike,
Sorry for the issue! Would you please be able to try restarting your Umbrel Home? You can press the power button once. Then when the LED on it goes off, press it again to bring the device back up. Once it’s up, let me know if you’re able to see the 1.0 update or not. If not, no worries - we can help you troubleshoot this further and update manually if required.
Thanks, but I have rebooted several times and tried installing new apps. I couldn’t even upgrade apps, but that seems to be working now.
I have seen this issue on my other Umbrel node, but that is a RPi, so I could just flash the card anyway.
Hold the front page, I’ve just logged on to check and it’s now offering the upgrade.
I’m upgrading now…
