Lightning Node with local RPC or connect
I noticed that lightning node id only allows for tor only. Is there anyway to add another option for local connect, I use light weight ip for peer to peer on my private connections and would like to remove TOR from infrastructure as I don’t trust it.
thanks for any pointers
