Hello everyone. I wanted to ask for some help configuring Lightning Nodes on an Umbrel system with the Testnet4 blockchain. As you know, in Umbrel and Testnet3 mode, it worked perfectly, automatically installing Bitcoin Core and Lightning Nodes without any further action until the network became saturated. Apparently, Umbrel has already implemented Lightning compatibility in Testnet4 in the last two OS updates… but… after installing Bitcoin Core and 100% synchronizing the Testnet4 blockchain, Lightning Nodes simply won’t sync with Bitcoin Core. I have two separate Umbrels installed on two separate Raspberry Pi 4s, each with its own Umbrel, Bitcoin Core node, and Lightning Node. Of course, everything works perfectly on the one running Mainnet mode. I’m explaining all this because this way I can print out both logs from the exact same operating system, umbrella, and machine where they’re installed—everything exactly the same—so we can compare the differences between the one that works on Mainnet and the one that doesn’t on Testnet4. At first glance, looking at the two logs, the startup log of the Testnet4 Lightning Node Docker container already shows an error, which I’ve underlined in purple: it can’t find the channel.backup file because it’s looking for it in a /Mainnet folder. I thank those who dedicate a little of their time to this in advance.
Hola a todos. Os quería pedir un poco de ayuda con la configuración de Lightning Node en sistema Umbrel con la cadena Tesnet4. Como sabéis en Umbrel y modo Tesnet3 funcionaba muy bien instalando Bitcoin Core y Linghtning Node de manera automática sin hacer nada hasta que se saturo la red. Umbrel por lo visto ya implementa la compatibilidad con Lightning en Tesnet4 en las ultimas las ultimas 2 actualizaciones de SO. .. pero… despues de instalar Bitcoin Core y sincronizar la blockchain testnet4 al 100% no hay manera que Lightnnig Node sincronice con Bitcoin Core. Yo Tengo instalado dos umbrels por separado en 2 Raspberrys Pi 4 separadas cada una con su umbrel, su nodo de Bitcoin Core, y su nodo de Lighnning Node. Por supuesto en la que tengo instalado el modo Mainnet funciona todo bien perfecto. Os explico todo esto porque de esta manera puedo imprimiros los 2 Losgs exactamente del mismo sistema operativo umbrel y misma maquina donde estan instalados, todo exactamante igual, para poder comparar las diferencias del que SI funciona en Mainnet VS el que no funciona Tesnet4. A simple vista mirando dos Logs, el Log de arranque del docker Lightnning Node de Tesnet4 ya veo que da un error que he subrayado en violeta que no encuentra el channel.backup porque lo esta buscando en una carpeta /Mainnet. Supongo el error es de ruta o edición de algun archivo que habra que editar algun parametro del código para que funcione Lightnning Node. Si encontramos la solución nos valdrá para toda la comunidad de principiantes que estamos aprendiendo. Os agradezco a los que le pongáis un poco de vuestro tiempo de antemano.
