Lightning Node Advancved Settings need update
Hello Umbrel Support,
after updating to Lightning Node 0.17.4 I realized the some lnd.conf settings have changed.
Most of the [routerrpc] settings have been update but in Lightning Node Advancved Settings
there is still routerrpc.penaltyhalflife but it has now changed to routerrpc.apriori.penaltyhalflife
Other parameters that have been changed are:
routerrpc.hopprob > routerrpc.apriori.hopprob
routerrpc.weight > routerrpc.apriori.weight
Please check and update Advanced Settings accordingly.
Also in case I want to run in mode routerrpc.estimator=bimodal how would this be reflected in Advanced settings?
Thanks a lot.
You should still be able to make these changes under lnd.conf, but I’ll share this feedback with the team.
Thank you for your answer and for sharing it with the team.
I know that I can still update the original lnd.conf with configuration options that are not present in ā€œAdvanced Settingsā€ of the LKightning Node App.
My concern is more about configuration options that are no longer available in lnd 0.17.4 like
routerrpc.penaltyhalflife and what effect this might have?
