Lightning channel won't restore
PLEASE HELP
My Umbrel node HD crashed…
I restored my node off the 24 word seed.
I have restored my wallet fund with the same seed in bluewallet.
I had 1 LND channel open and was provided the most current update of my channel from the umbrel DEV team with these instructions.
gist.github.com
https://gist.github.com/louneskmt/e4093a62aa1ae8788ef5d92c119f22a8
Restore backup - Umbrel.md
#### Step 1: Copy over the encrypted backup file from your computer to your Umbrel.
Open the “Terminal” app on Mac/Linux, or “PowerShell” on Windows and run this:
scp <path/to/your/encrypted/backup/file> umbrel@umbrel.local:/tmp/backup.tar.gz.pgp
_(Replace `<path/to/your/encrypted/backup/file>` with the exact path to encrypted backup file on your computer)_
_(Exemple of file: `123456789.tar.gz.pgp`)_
This file has been truncated. show original
They will not work for me. I have the file on my desktop
I type this in terminal
scp <Users/goodfellas/Desktop/1637643702336.tar.gz.pgp > umbrel@umbrel.local:/tmp/backup.tar.gz.pgp
It says this.
-bash: Users/goodfellas/Desktop/1637643702336.tar.gz.pgp: No such file or directory
any help would be very appreciated.
Your terminal is telling you the file doesn’t exist or is typed wrong. Are you entering it in your umbrel?
To me it looks like the file is on a windows or dos file system structure. the scp command should be done from there (windows computer) on the same network, if windows has “scp” I don’t know much about windows.
You are just trying to copy it over to your temporary directory on your umbrel “/tmp” this could be done many ways including in a regular file browser if the computer is set to sharing
I am on a Mac
From the Mac terminal make sure you can get to your desktop folder with a change directory
cd /Users/goodfellas/Desktop
If that works then list the directory
ls
You should see the file you want to move.
Type obviously change file name variable
scp ./thefilename umbrel@umbrel.local:/tmp/backup.tar.gz.pgp
Image attached. Sorry, I am trying to learn terminal
Looks like the directory was good the issue must be the filename.
Run the list command
ls
And look for the file you want
Just put
./ Then the filename no previous directory
Something like this
scp ./1637643702336.tar.gz.pgp umbrel@umbrel.local:/tmp/backup.tar.gz.pgp
Note I had a typo before this is correct
Hey, I think this was already figured out on the Telegram, but his channel backup still isn’t working, pinging @louneskmt on this one (mentioned in our Telegram chat), user is receiving this error:
You had to execute that command in the Desktop directory ie. After the first cd command
User is using the wrong pgp password key it appears
Can you show me step by step how to do it correct. I am trying to learn.
