Jellyfin default user/password
Hello,
I installed Umbrel 1.1 on a PC and the install Jellyfin.
I need an user/password to login.
What is the default user/password?
Tks
Rodrigo
Hi @chocksmith
To find the credentials, please right-click the app on the main dashboard.
Hi! Thanks for the response.
That’s what I see. No credentials.
I see what @smolgrrr is referring to for some apps, like Nextcloud, that are setup with default creds, which you should then change. However, Jellyfin is not an app that is setup that way.
First time opening Jellyfin should prompt you to setup your first admin account’s username/password. Does it not do this for you? Could try reinstalling if not.
