I am experiencing an issue with my Umbrel node where the App Store remains blank. I have attempted several troubleshooting steps without success, and I am seeking further assistance.
Umbrel Version: 0.5.4
Troubleshooting Steps Taken:
- Tried accessing the App Store using both Chrome and Firefox browsers.
- Confirmed no network connectivity issues.
- Reviewed Umbrel logs and system status.
- Run the following script found in support and troubleshooting: sudo rm -f ~/umbrel/repos/https—github-com-getumbrel-umbrel-apps-git/.git/index.lock && sudo rm -f ~/umbrel/repos/https—github-com-getumbrel-umbrel-apps-git/.git/ORIG_HEAD.lock && sudo ~/umbrel/scripts/repo update
Notable Observations:
- The system has sufficient memory and no apparent filesystem issues.
- Docker containers for essential services are active and running.
- Repeated log entries in Karen logs indicating a potential issue with event handling or script execution:
/home/aldo/umbrel/events/triggers/. - No direct errors or issues related to the App Store functionality in the logs.
- Tor proxy functioning correctly.
I am copying the detailed debug logs for your review. I would appreciate any guidance or assistance you can provide to resolve this issue.
0.5.4
Mem: 7,8G 3,2G 877M 758M 3,7G 3,6G
Swap: 2,0G 0B 2,0G
total: 41,1%
system: %
Memory monitor logs
2023-12-13 00:36:29 Memory monitor running!
18924 ? S 0:00 bash ./scripts/memory-monitor
2023-12-13 07:57:52 Memory monitor running!
2023-12-13 08:13:17 Memory monitor running!
2023-12-13 08:46:41 Memory monitor running!
2023-12-13 17:37:25 Memory monitor running!
2023-12-13 20:40:19 Memory monitor running!
2023-12-13 23:57:34 Memory monitor running!
2023-12-14 00:15:51 Memory monitor running!
/dev/sda3 164G 17G 139G 11% /
Karen logs
Got signal:
karen is getting triggered!
Got signal:
./karen: line 75: /home/aldo/umbrel/events/triggers/: Is a directory
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal: debug
Docker containers
NAMES STATUS
nginx Up 6 hours
dashboard Up 6 hours
manager Up 34 minutes
auth Up 6 hours
tor_proxy Up 6 hours
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:18:49 GMT] “GET /v1/system/get-update HTTP/1.0” 304 - “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:120.0) Gecko/20100101 Firefox/120.0”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:18:55 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:18:55 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:18:55 GMT] “GET /v1/apps HTTP/1.0” 304 - “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:18:55 GMT] “GET /v1/system/memory HTTP/1.0” 200 86 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:18:55 GMT] “GET /v1/system/storage HTTP/1.0” 200 90 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:18:56 GMT] “GET /v1/system/get-update HTTP/1.0” 304 - “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:18:58 GMT] “POST /v1/system/debug HTTP/1.0” 200 17 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:120.0) Gecko/20100101 Firefox/120.0”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:19:00 GMT] “GET /v1/system/debug-result HTTP/1.0” 200 23 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:120.0) Gecko/20100101 Firefox/120.0”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 14 Dec 2023 11:19:01 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:120.0) Gecko/20100101 Firefox/120.0”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Dec 14 05:16:26.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Dec 14 05:16:26.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Dec 14 05:16:27.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Dec 14 05:16:27.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Dec 14 05:16:27.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Dec 14 05:16:27.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Dec 14 05:16:27.000 [notice] Bootstrapped 100% (done): Done
tor_proxy | Dec 14 11:15:58.000 [notice] Heartbeat: Tor’s uptime is 6:00 hours, with 0 circuits open. I’ve sent 1.89 MB and received 14.59 MB. I’ve received 2 connections on IPv4 and 0 on IPv6. I’ve made 14 connections with IPv4 and 0 with IPv6.
tor_proxy | Dec 14 11:15:58.000 [notice] While bootstrapping, fetched this many bytes: 699491 (consensus network-status fetch); 14104 (authority cert fetch); 12370176 (microdescriptor fetch)
tor_proxy | Dec 14 11:15:58.000 [notice] While not bootstrapping, fetched this many bytes: 49427 (consensus network-status fetch); 13056 (authority cert fetch); 221558 (microdescriptor fetch)
==== Result ====
==== END =====
