NO apps on appstore
Continuing the discussion from No apps on app store:
My fresh instalation do not show apps on app store. Can anybody help me. That is what I see on debug file:
0.5.4
Mem: 15G 2,8G 8,4G 830M 4,7G 11G
Swap: 2,0G 0B 2,0G
total: 17,5%
system: %
Memory monitor logs
2023-08-08 16:54:43 Memory monitor running!
2023-08-08 17:31:40 Memory monitor running!
2023-08-08 17:49:17 Memory monitor running!
2023-08-08 17:53:34 Memory monitor running!
2023-08-08 22:18:05 Memory monitor running!
2023-08-09 13:00:38 Memory monitor running!
2023-08-09 13:41:28 Memory monitor running!
2023-08-09 19:51:20 Memory monitor running!
2023-08-09 19:59:26 Memory monitor running!
/dev/nvme0n1p2 916G 20G 850G 3% /
Karen logs
Removing dashboard … error
Removing nginx … done
Removing nginx … error
Removing auth … done
Removing tor_proxy … error
Removing auth … error
Removing tor_server … done
Removing dashboard … done
Removing manager … done
Removing tor_proxy … done
ERROR: for nginx removal of container f76b80385607033f27e5e7b074e3c51b0e6b342c1ff5f63f74dc2c8a06e6c929 is already in progress
ERROR: for tor_proxy removal of container db92c2f99e49ee324464099b9c7c8180836b30e55c065dc4b8e3a20e4950c344 is already in progress
Removing tor_server … error
ERROR: for manager removal of container 0748ca5a1cdc9e19273a36d7ca0bb32bd7a40842ea23d09ffc69c5a7f37981a2 is already in progress
ERROR: for dashboard removal of container da8cdf54dee14a465ffb77c71475869dcd6726179fab06608cce56ce840f5645 is already in progress
ERROR: for auth removal of container d0f506be79adc53a947197f4ee64df8d98a664082ab0ac3690da6a826577f00e is already in progress
ERROR: for tor_server No such container: e5c09e7188d48d5f21ad8f6bb3fb72a0996bdf982127ee0643270ea860e913f4
Network umbrel_main_network not found.
karen is running in /home/e/umbrel/events
Got signal:
karen is getting triggered!
./karen: line 75: /home/e/umbrel/events/triggers/: Is a directory
Got signal:
Got signal: change-password
This script must only be run on Umbrel OS
Got signal: debug
Debug result file generated
Got signal:
Got signal:
Got signal: debug
Docker containers
NAMES STATUS
nginx Up About an hour
tor_proxy Up About an hour
tor_server Up About an hour
manager Up 9 minutes
dashboard Up About an hour
auth Up About an hour
Umbrel logs
Attaching to manager
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Thu, 10 Aug 2023 02:14:39 GMT] “GET /v1/system/info HTTP/1.0” 200 671 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 OPR/101.0.0.0”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 10 Aug 2023 02:14:39 GMT] “GET /v1/system/uptime HTTP/1.0” 200 4 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 OPR/101.0.0.0”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 10 Aug 2023 02:14:39 GMT] “GET /v1/system/remote-tor-access-status HTTP/1.0” 200 35 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 OPR/101.0.0.0”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 10 Aug 2023 02:14:39 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 OPR/101.0.0.0”
manager |
manager | Error reading directory: /repos/https—github-com-getumbrel-umbrel-apps-git Error: ENOENT: no such file or directory, scandir ‘/repos/https—github-com-getumbrel-umbrel-apps-git’
manager | at Object.readdirSync (fs.js:955:3)
manager | at Object.listDirsInDir (/app/services/disk.js:77:23)
manager | at Object.get (/app/logic/apps.js:147:33)
manager | at async /app/routes/v1/apps.js:16:18
manager | at async /app/utils/safeHandler.js:8:14 {
manager | errno: -2,
manager | syscall: ‘scandir’,
manager | code: ‘ENOENT’,
manager | path: ‘/repos/https—github-com-getumbrel-umbrel-apps-git’
manager | }
manager | ::ffff:10.21.21.2 - - [Thu, 10 Aug 2023 02:14:39 GMT] “GET /v1/apps HTTP/1.0” 304 - “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 OPR/101.0.0.0”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 10 Aug 2023 02:14:43 GMT] “POST /v1/system/debug HTTP/1.0” 200 17 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 OPR/101.0.0.0”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Aug 10 01:08:16.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_proxy | Aug 10 01:08:16.000 [warn] Bad element “$C623F97858DDC20DC80098260DFDF053” while parsing a node family.
tor_proxy | Aug 10 01:08:17.000 [warn] Bad element “$F04AC” while parsing a node family.
tor_proxy | Aug 10 01:08:29.000 [notice] Bootstrapped 65% (loading_descriptors): Loading relay descriptors
tor_proxy | Aug 10 01:08:50.000 [notice] Bootstrapped 70% (loading_descriptors): Loading relay descriptors
tor_proxy | Aug 10 01:09:01.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Aug 10 01:09:01.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Aug 10 01:09:01.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Aug 10 01:09:56.000 [notice] Bootstrapped 100% (done): Done
tor_proxy | Aug 10 01:10:39.000 [warn] Bad element “$AA4644F0EC589EEA2F501BB867E32E599F816” while parsing a node family.
==== Result ====
==== END =====
Did the solution mentioned in the last thread not help?
Hello, I had to reinstall my umbrel to a new 2 Terabit disk. Over ubuntu 22.04 and again the app store do not work. When I try the unstuck step " sudo scripts/ repo update" I get: “sudo: scripts/repo: command not found”
Also I tried on debian 12 and the same is happening. My hair is whitening, can you help me one more time?
Hmm that sounds like maybe a bad installation or the wrong directory.
Can you please try the following command all together, and let me know if you get the same issue.
sudo rm -f ~/umbrel/repos/https—github-com-getumbrel-umbrel-apps-git/.git/index.lock && sudo rm -f ~/umbrel/repos/https—github-com-getumbrel-umbrel-apps-git/.git/ORIG_HEAD.lock && sudo ~/umbrel/scripts/repo update
Thanks!
Did you make any progress? I have the same situation and I’ve reinstalled repeatedly >:(
