Ip address question
I reserved an ip address in the static DHCP table on my router and Umbrel worked fine but now the address has changed and Umbrel is no longer working. When I ping my router the original address doesn’t show up yet the address is still reserved in the table of my ISP.
I contacted my ISP and was told I can get a static address from them but I’m not sure if it’s needed and if so how do I change the address Umbrel is using which was used when I first installed it on my Pi?
Any advice is appreciated.
I’d just clear the dhcp and set a reserved ip outside the dhcp pool. Or set a static dhcp by mac address. - on any change reset the router and node to flush the tables.
Thank you. I’ll give it a try next week when I have more time.
