Invidious "Not Running"
Prompt that update to Invidious was available. Updated. Full day of progress bar showing update in progress but no update. Restarted Umbrel. Umbrel icon present, below it the words “Not running.” Click to open has no effect. Direct link to open brings “Unable to connect” error screen. Right click reveals “Edit widgets / Change wallpaper / Log out” but not the usual app choices. Shown in app store as “Not running” with no install / uninstall option. Have tried waiting, restarting, rebooting, above state endures.
Goal: use Invidious. Okay to uninstall and reinstall, okay to use command line, many thanks in advance for help.
Had the same issue, this solved it for me:
Thank you, this did the trick!
