Introducing Backups on umbrelOS
umbrelOS 1.5 Beta 1 brings automatic encrypted Backups, Rewind in Files, network drive mounts, external USB storage support on amd64 devices, and several performance improvements and bug fixes.
Watch the release: https://www.youtube.com/watch?v=alarI_6uU9A
New features
  • Backups: umbrelOS can now automatically back up all of your files, apps, and data to another Umbrel or a NAS on your network, or an external USB drive.
  • Rewind in Files: Time travel through your backups to restore specific files and folders from any point in the past.
  • Network mounts in Files: Mount network drives and shares, like another Umbrel or a NAS, and browse them directly within Files.
  • External storage (amd64): External USB storage is now supported across all amd64 (Intel or AMD) devices and the Umbrel Home.
  • Additional bug fixes and performance improvements.
Arriving in umbrelOS 1.5 this October. Public beta now available for all users running umbrelOS on:
  • Umbrel Home
  • Raspberry Pi 4 and Pi 5
  • All other supported devices
To try it out, go to Settings > Advanced settings, and enroll into the umbrelOS Beta Program.
Note: Please make sure all your apps are updated to their latest versions so they work seamlessly with Backups.
Join the official umbrelOS Beta channel on Umbrel Community Discord to share your feedback on this beta and engage with other users.
Super nice, this is a very good update. I always wanted to back up my Umbrel in case my hard drive gives out
Hi @mayank
could you please clarify the requirements for the USB backup?
I tried using a USB thumb drive, but it’s not being recognized.
Is there a specific file system required? Do we need to format the drive before using it, or will Umbrel handle the formatting automatically?
Thanks,
Thomas
Looking forward to when the confidence in Umbrel Backups expressed on x is equal to the confidence in moving Umbrel Backups out of beta and into the main OS “in October” (ten days left).
Do you mean I can have a mirror server, another umbrel as backup? Always in my network or even on another lan?
I hope so too. Unfortunately, there’s little known about the beta’s status. I couldn’t find much progress information on the bugs discovered in the beta release. Even on the Umbrel Discord, I found nothing about the issues with the new Umbrel OS version 1.5.
I assume they’ll only roll it out to the main OS once everything is deemed code-technically sound. In that regard, it’s uncertain whether it’ll happen by the end of October.
Almost perfect. Just missing configurable backup scheduling. A backup every hour is to much for me.
Is there a way to configure the underlaying kopia?
Hi @pkamm, there isn’t currently a supported way to change the backup schedule or configure Kopia directly.
However, backups are incremental. After the first full backup, each hourly run only saves what has changed since the previous backup rather than copying everything again. If little or nothing has changed, the backup will use very little additional storage or bandwidth, so the hourly schedule shouldn’t be a concern.
Hello @aidencole
Thank you very much for your feedback.
I’m aware of the incremental nature of the backup behind umbrel, but I run umbrel on a pretty low-end minipc in my living room and annoyingly even this little task causes the fans to spin up. Therefore I would love to change the schedule to a daily backup at night-time, which would be enough for me and quiet during the day.
Three things for the Umbrel team
  1. Backup failures need to surface in the UI.
    An inode exhaustion is recoverable in five minutes once you know, but I had no way to know.
    A “last successful backup” age indicator on the dashboard would have caught this on day one.
  2. Don’t reset kopia’s cache config on every repository operation. This one removes the
    only workaround owners have. Either stop rewriting the caching block on repository connect, or pass explicit cache limits when you do.
  3. Ship hard limits sized for the boot medium. Soft-limit-only defaults tuned for a desktop
    are dangerous on a 19 GB SD partition with 1.26 M inodes, and indexes/index-blobs having
    no limit at all compounds it — especially given the deadlock makes the result unrecoverable
    without shell access.
