Installing Lightning node
I can’t install by App Store or by command on terminal.
How can I Fix it?
Hi @arthurclf this issue has come up for a couple users recently, could you please share the troubleshooting logs for your system
sudo ~/umbrel/scripts/debug
Thanks for helping me! It’s very difficult for a newbie :wink:
But every command that I type it says “command not found”… for installation ou debug its the same.
You can also generate these logs from the main settings :slight_smile:
