Installing a virtual machine on a different drive
According to help when creating a machine (win xp) there is supposed to be advanced options. I can’t find where I choose advanced options.
"Yes—you can create a Machine with its disk on a USB drive or network device instead of internal storage.
  1. Open Machines → Add machine.
  2. Choose the operating system.
  3. In the creation advanced options, choose the drive or network device as the disk location.
  4. Finish creating the machine.
The drive must stay connected whenever the machine runs. Machine disks stored externally aren’t included in umbrelOS backups."
The “Advanced” section only appears when you choose “Custom machine” and supply your own ISO or disk image. Picking Windows XP directly from the catalog doesn’t show it, so the help reply left out that distinction.
With a custom image, you’ll find “Advanced” below the machine specs, then “Virtual disk location” to select a folder on your USB drive or network share. That route means supplying your own installer and setting up Windows yourself rather than using the catalog’s XP setup.
