Install problem
I get the following message
Sub-process /usr/bin/dpkg returned an error code (1)
after doing
Im running c-lightning on Ubuntu 22.10
I think I should include the line before it;
sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq --no-install-recommends docker-ce docker-ce-cli containerd.io docker-compose-plugin docker-scan-plugin >/dev/null
E: Sub-process /usr/bin/dpkg returned an error code (1)
and I appreciate it if someone could explain if this matters, I think it must thanks
well I got past that, I just ran sudo apt install --fix-broken, and now the problem is;
ERROR: for tor_proxy Cannot start service tor_proxy: driver failed programming external connectivity on endpoint tor_proxy (655ff1c9131b7e80a25e01c97c63ce50b7efc973c6bbe012d72483fa015308ad): Error starting userland proxy: listen tcp4 127.0.0.1:9050: bind: address already in use
ERROR: Encountered errors while bringing up the project.
Failed to start containers
i am experiencing the same problem :frowning:
