Immich external library wit local path on umbrel
how can I acces the local files with immich, so that a local path opn my umbrel will be available as an external library in immich?
Thanks,
Faultbendfold
and the same I would like to do with nextcloud, so that i have access to one specific path on umbrel via nextcloud.
same question to know how the new folder structure in vers. 17.1 can connect to immich as an external bibl.
well, this screenshot helps ??
to my understanding the problem lies with umbrel os, that only permits local mounted folders to docker containers or apps, when they have admin rights. But every update deletes the admin rights.
