The new Photos app on Umbrel 2.0 does not find any of my pictures on Immich stored on the same drive? Source and All files selected.
Anybody know of a fix?
And is there a way to import all of the Albums from Immich too?
hey, Photos doesn’t look inside app folders, so it won’t pick up Immich’s photos even with “All files” selected.
In Files, go to Apps > Immich > data > upload and copy the library and upload folders into your Photos folder. Photos should then start picking them up. Copy rather than move if you’re still using Immich.
There’s a guide here with screenshots: Moving from Immich | umbrelOS Support
Albums don’t transfer over, since those are stored in Immich’s database rather than in the photos themselves. The guide also covers using both apps side by side if you’d rather keep Immich around.
Fantastic thanks for the detailed reply. I will give that a go
