Imac and Umbrel
I read that with the release of umbrel 1.x it is developed for the Home box, and it is mandatory to install debian with it. Older release 0.54 of umbrel was working like a charm on iMac running ubuntu-mate (dockers). Where I can find the older install script for 0.54?
I run umbrel 1.2 on mac mini with no major issues. It should be the same with iMac, shouldn’t it?
Good to know. Thanks. How did you install it? I have used Balena and a usb key, and it installed everything. However I was expecting to see a graphical interface, instead I got only the terminal prompt with the umbrel login. Is this normal?
Yes, I think so. You can access the umbelOS dashboard via web browser on different device.
Thank you. It works exactly as the HOME device. But it also means that my beautiful 27" display of my iMac will always be used only in terminal mode.
I think so and I am afraid there is no workaround. But I might be wrong.
