I'm not able to adjust the cooling fan
Umbrel is now good to go on my Pi 5. I’ve also plugged the official Raspberry cooling fan onto the board. The only problem is that the fan keeps turning on every minute for a few seconds and then turning off again, which gets annoying. I think it turns on automatically when it hits 60 degrees Celsius and stops at 55. How can I adjust it so that it only turns on at 70 and stops at 60?
I asked ChatGPT, but when I use the Umbrel terminal (umbrel@umbrel) and paste the first script sudo nano /boot/firmware/config.txt, it doesn’t find anything.
Does anyone know how to handle this?
