Anyone know if Umbrel has fan control settings somewhere? The cooling fan attached to my Raspberry Pi isn’t turning on but I’m not sure if it’s the hardware or temperature settings. If there is no fan control through Umbrel, is there another way to control the temp at which the fan turns on? I see temperature in my Umbrel settings but no options to control anything. I’m new to Umbrel and Raspberry Pi (obviously) so any help would be appreciated.
Which case are you using?
For my case there is a script available on the manufacturers homepage which allows me to set the temperature / fan speed ratios individually.
Glad I could help! Btw I have the same case as you
The triton cases are so clean
