Hi~
꜆₍ᐢ˶•ᴗ•˶ᐢ₎꜆
I updated the umbrelOS 1.3 and I can’t login.
How to login the umbrelOS 1.3?
I did the below,
umbrel login: umbrel
Password: umbrel
but, I can’t login.
Hi~
꜆₍ᐢ˶•ᴗ•˶ᐢ₎꜆
I did the below,
Password: umbrel
but, I can’t login.
With so little information it is difficult to know the cause of the problem…
Based on what you say I assume:
You only have to enter the password of the user you created the first time you configured umbrelos.
I don’t see anything else or you are not providing any more data that indicates otherwise.
Thank you for your reply…^^
I installed the umbrelOS 1.0 again.
Just, I am using the umbrelOS 1.0.
