Dear community,
I can’t verify Transactions from Umbrel (Via Mempool or BTC Explorer) because Electrs is not synchronized. I am reaching out to you because I am stuck with this issue for while now, and haven’t found any useful answer in older posts.
I am running Umbrel 0.5.3, BTC Node sync at 100% on a Pi 8 mb of ram, 1 T SSD.
Eletrcs status is: Waiting for Bitcoin Node to finish syncing…
I did some troubleshouting (restart Umbrel, shutdown, reinstall these apps): it worked and Electrcs synchronized to 100% and could even find wallet/tx on Mempool - but only for a while. Then Electrs lost sync again : Waiting for Bitcoin Node to finish syncing…
I would be grateful if you had any suggestion…
Thanks in advance
Baseload.
