I can access to umbrel but when I use Thunderhub or Ride the lightning or any other app, I can´t connect to my node. It gives me an error: “unable to connect to this node”
What can I do?
Thanks
What can I do?
Thanks
Are you using Umbrel Store apps to connect or are you trying to connect a separate from Umbrel Thunderhub installation?
I´m using Umbrel Store apps to connect.
