How to Connect Node to Ledger
Hi
What is the current recommendation for connecting a Ledger cold wallter to Umbrel node?
To connect your Ledger cold wallet to your Umbrel node, use a desktop wallet like Sparrow, Electrum, or Specter Desktop. These apps allow integration with your node via RPC credentials provided by Umbrel.
Check out this thread:
I am not advanced. I tried following that other article.I need step by step instructions to integrate with RPC credentials.
Hey @denny
I purchased Nunchuk’s ‘iron hand’ for multisig and created a multisig wallet. Nunchuk has RPC as well but I am a noobie.
Would you have any insight into finding the node’s RPC credentials?
Thank you
