How to change the alias name in Core Lightning Node?
In Lightning Node (LND) it´s easily possible to adjust the alias name.
How can I do the same thing if I want to use the Core Lightning Node ?
I believe you can add it here, but I’ll need to confirm.
sudo nano ~/umbrel/app-data/core-lightning/data/app/config.json
“unit”: “SATS”,
“fiatUnit”: “AUD”,
“appMode”:“DARK”,
“isLoading”: false,
“error”: null,
“alias”: “…”,
I tried to customize my Core LND name as well, only to get a black screen after logging in, I uninstalled and reinstalled and got a new name, but not the custom one I set in the plain lightning, anyone have a way to set the same name in CORE lnd?
Sorry I can´t help you here because in the end I didn´t install Core Lightning but LND
Thanks for the reply! I got it sorted by uninstalling and reinstalling, appreciate your help!
To Umbrel OS 1.1.2 sudo nano /umbrel/app-data/lightining/data/lightining/settings.json
It didn’t work for me. How can I change the node name? Is there another file than I can change?
