Will check on the 21st too
Ok. Crash happened around 10 am New York time Sun Aug 20. Not Aug 21 that’s a typo on my part. Backup file I believe should be 1692500044648.tar.gz.pgp for backup ID 7ca6258b54102ec4b77a37e341c3a93a932c1b3e1f8a1860b1bccbe6b9d63003"}
Thank you
Clint Farrell
Hi - I’m also trying to install chantools but get an error with this too, can you help? I really appreciate your help BTW. I run a Windows 10 PC.
umbrel@umbrel:/tmp $ wget -O chantools.tar.gz https://github.com/lightninglabs/chantools/releases/download/v0.11.3/chantools-windows-386-v0.11.3.zip
–2023-09-26 15:13:51-- https://github.com/lightninglabs/chantools/releases/download/v0.11.3/chantools-windows-386-v0.11.3.zip
Resolving github.com (github.com)… 140.82.112.3
Connecting to github.com (github.com)|140.82.112.3|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/220655807/e792538c-fa1a-4dc3-a430-a5908a0adecf?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20230926%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20230926T151352Z&X-Amz-Expires=300&X-Amz-Signature=379e0b3a77667e8db9fde5c9112eaad43f0558853a8f828d033b01f8d14ead53&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=220655807&response-content-disposition=attachment%3B%20filename%3Dchantools-windows-386-v0.11.3.zip&response-content-type=application%2Foctet-stream [following]
–2023-09-26 15:13:52-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/220655807/e792538c-fa1a-4dc3-a430-a5908a0adecf?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20230926%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20230926T151352Z&X-Amz-Expires=300&X-Amz-Signature=379e0b3a77667e8db9fde5c9112eaad43f0558853a8f828d033b01f8d14ead53&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=220655807&response-content-disposition=attachment%3B%20filename%3Dchantools-windows-386-v0.11.3.zip&response-content-type=application%2Foctet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)… 185.199.110.133, 185.199.111.133, 185.199.108.133, …
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.110.133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 10644275 (10M) [application/octet-stream]
Saving to: ‘chantools.tar.gz’
chantools.tar.gz 100%[=================================================>] 10.15M 24.2MB/s in 0.4s
2023-09-26 15:13:52 (24.2 MB/s) - ‘chantools.tar.gz’ saved [10644275/10644275]
umbrel@umbrel:/tmp $ tar -zxvf chantools.tar.gz
gzip: stdin has more than one entry–rest ignored
tar: Child returned status 2
tar: Error is not recoverable: exiting now
umbrel@umbrel:/tmp $ sudo mv chantools-*/chantools /usr/local/bin/
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for umbrel:
mv: cannot stat ‘chantools-*/chantools’: No such file or directory
I’m trying to use chantools too and it’s very poorly explained. I don’t even know if chantools is properly installed, how can I tell
I’m trying triggerforceclose, i.e.,
chantools triggerforceclose \
--peer [03abce...@xx.yy.zz.aa:9735](mailto:03abce...@xx.yy.zz.aa:9735) \
--channel_point abcdef01234...:x
I have the peer remote_node_pub but I have no idea what to use for host and port
I get this error every time -bash: /usr/local/bin/chantools: cannot execute binary file: Exec format error
Alternatively I hope you can provide the db backup 1692500044648.tar.gz.pgp for backup ID 7ca6258b54102ec4b77a37e341c3a93a932c1b3e1f8a1860b1bccbe6b9d63003
This is a real disappointment, i hope you can help me
Thank you
Clint Farrell
dm’d you two more back-ups
Someone on Telegram is telling me to re-fund a channel giving me an address but not explaining where the address came from -copied here
usernameisJim (will not DM you), [9/27/2023 3:00 AM]
I have to open the Umbrel database. so you can continue……
On the peer node, you’ll have the htlc smart contract Onchain synced BTC address to fund and create back up for channel on your node; Here it is
1CbYYCv5gspxMK1JHLvPAL9r75PH8WTrZv
You’re to fund the above
Synced BTC address to continue with this capacity below ![]()
Capacity
0.10000000 BTC (0.002267%) 10,000,000 sat
$2,624.89
Channel Id
852866980475305985
Short Channel Id
775678x996x1
775678:996:1
Node: Gotagreatdog
usernameisJim (will not DM you), [9/27/2023 3:01 AM]
The funds meant to create the back up channel will be forwarded to your node balance once the processing is completed
Clint Farrell, [9/27/2023 3:02 AM]
What do you mean fund and create back up channel?
Clint Farrell, [9/27/2023 3:04 AM]
So send bitcoin to that address? Is this a scam
usernameisJim (will not DM you), [9/27/2023 3:07 AM]
Using the htlc smart contract OnChain Synced BTC address to peer Node: Gotagreatdog.
Is there a way to load backups via ssh commands?
That is a scam/spam telegram account please ignore it- unfortunately we cannot do anything about them.
We will need to use chantools from here I believe. By any chance, do you know the people that run the nodes of the remaining channels you have? This can make the process easier
Hi - I got 2 of the 4 channels to force close on their side. I see the channel activity on Amboss but those channels don’t appear in my node channel list as I can’t load any backup, just gives an error. What next? Will funds arrive in my node wallet?
Hello
I was able to contact 2 node owners and they closed their channels. I’m trying to install/run chantools and it just won’t work. Can you please walk me through the process to 1) install chantools in umbrel, 2) recover funds from closed channels (ie., do I need to create a fake backup, if so, how? How exactly do I call the sweep command? I’m reading the chantools documentation but having a very hard time trying to interpret it.
Much appreciated, thank you
Clint
Hello
How do I install this backup file 1692500044648.tar.gz.pgp?
Thank you
Clint
Hi - what exactly is the process for installing the backups? I might be doing it wrong. I’m hoping I can then close this channel where the other node is dead, it’s Tor so chantools doesn’t work
https://amboss.space/node/02defb1fcf3d8e6254abffe422327ab049848b80d2198bf41afb39d86ee70c4797
Thank you,
Clint
