Can't finding channle and pending force closing
Hello everyone.
My node can’t access due to guess channel.db overf
Untitled
low for install Torq.
Then, I left it alone few month.(Stupidly!!)
Recently, I contact umbrel official support to gave channel backup. But I can’t response they.
So I have shutdowned my node, but I haven’t load a channel backup when recovery a seed phrase.
But I can find three channels for 1ML(https://1ml.com/node/03ae10e0b22bcd331c04feb70acc0957bd2f4a112d4cc4ae1f23893d06c9e0aede/channels)
I’d like to close these channel, so I contact a manager of one of these channel.
and he closed channel.
but this channel unconfirmed due to low fee(mempool - Bitcoin Explorer
So I tried CPFP , but I received error that bellow.
[lncli] rpc error: code = Unknown desc = the passed output does not belong to th e wallet
and My lnd responce I have’t active channels as attached.
Can I close these three channels by CPFP?
Or these three channels already closed?
Best Regard.
Hi if you can go to settings and select ‘START’ under troubleshooting, then share the log here I can forward you the back-up.
Otherwise, if you update the lightning app this should populate automatically now.
Thank you for your help!
Actually, I had left error while few month. And I restore node two weeks ago by seed phrase.
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision	: d03115
Serial		: 10000000bfff9df2
Model		: Raspberry Pi 4 Model B Rev 1.5
Firmware
May  9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=43.8'C
Throttling
throttled=0x0
Mem:           7.8G        2.2G        104M        4.0M        5.5G        5.5G
Swap:          4.1G        1.3G        2.8G
total: 28.4%
bitcoin: 13.7%
lightning: 13.5%
ride-the-lightning: 0.6%
thunderhub: 0.3%
system: 0.3%
Memory monitor logs
2023-10-21 02:06:45 Memory monitor running!
/dev/root        15G  3.2G   11G  24% /
/dev/sda1       916G  627G  243G  73% /home/umbrel/umbrel
Startup service logs
Oct 21 02:06:45 umbrel umbrel startup[2340]: ======================================
Oct 21 02:06:45 umbrel umbrel startup[2340]: Setting environment variables...
Oct 21 02:06:45 umbrel umbrel startup[2340]: Starting karen...
Oct 21 02:06:45 umbrel umbrel startup[2340]: Starting status monitors...
Oct 21 02:06:45 umbrel umbrel startup[2340]: Starting memory monitor...
Oct 21 02:06:45 umbrel umbrel startup[2340]: Starting backup monitor...
Oct 21 02:06:45 umbrel umbrel startup[2340]: Starting decoy backup trigger...
Oct 21 02:06:45 umbrel umbrel startup[2340]: Starting umbreld...
Oct 21 02:06:45 umbrel umbrel startup[2340]: Starting Docker services...
Oct 21 02:06:48 umbrel umbrel startup[2340]: Creating network "umbrel_main_network" with the default driver
Oct 21 02:06:48 umbrel umbrel startup[2340]: Creating auth ...
Oct 21 02:06:48 umbrel umbrel startup[2340]: Creating manager ...
Oct 21 02:06:48 umbrel umbrel startup[2340]: Creating tor_proxy ...
Oct 21 02:06:48 umbrel umbrel startup[2340]: Creating dashboard ...
Oct 21 02:06:52 umbrel umbrel startup[2340]: Creating manager   ... done
Oct 21 02:06:52 umbrel umbrel startup[2340]: Creating auth      ... done
Oct 21 02:06:52 umbrel umbrel startup[2340]: Creating dashboard ... done
Oct 21 02:06:52 umbrel umbrel startup[2340]: Creating nginx     ...
Oct 21 02:06:53 umbrel umbrel startup[2340]: Creating tor_proxy ... done
Oct 21 02:06:53 umbrel umbrel startup[2340]: Creating nginx     ... done
Oct 21 02:06:54 umbrel umbrel startup[2340]: Removing status server iptables entry...
Oct 21 02:06:54 umbrel umbrel startup[2340]: Removed existing iptables entry.
Oct 21 02:06:54 umbrel umbrel startup[2340]: Starting installed apps...
Oct 21 02:06:54 umbrel umbrel startup[2340]: Umbrel is now accessible at
Oct 21 02:06:54 umbrel umbrel startup[2340]:   http://umbrel.local
Oct 21 02:06:54 umbrel umbrel startup[2340]:   http://192.168.11.9
Oct 21 02:06:54 umbrel systemd[1]: Started Umbrel Startup Service.
Oct 21 02:11:37 umbrel passwd[5870]: pam_unix(passwd:chauthtok): password changed for umbrel
Oct 21 02:18:23 umbrel passwd[11566]: pam_unix(passwd:chauthtok): password changed for umbrel
Nov 09 15:10:02 umbrel passwd[2863]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
Oct 16 13:26:05 umbrel external storage mounter[511]: Formatting device...
Oct 16 13:26:05 umbrel external storage mounter[511]: mke2fs 1.44.5 (15-Dec-2018)
Oct 16 13:26:05 umbrel external storage mounter[511]: Creating filesystem with 244190208 4k blocks and 61054976 inodes
Oct 16 13:26:05 umbrel external storage mounter[511]: Filesystem UUID: df70d96d-6a41-4458-ac92-bc361866ef91
Oct 16 13:26:05 umbrel external storage mounter[511]: Superblock backups stored on blocks:
Oct 16 13:26:05 umbrel external storage mounter[511]:         32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
Oct 16 13:26:05 umbrel external storage mounter[511]:         4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
Oct 16 13:26:05 umbrel external storage mounter[511]:         102400000, 214990848
Oct 16 13:26:05 umbrel external storage mounter[511]: [65B blob data]
Oct 16 13:26:05 umbrel external storage mounter[511]: [62B blob data]
Oct 16 13:26:07 umbrel external storage mounter[511]: Creating journal (262144 blocks): done
Oct 16 13:26:12 umbrel external storage mounter[511]: [117B blob data]
Oct 16 13:26:12 umbrel external storage mounter[511]: Mounting partition...
Oct 16 13:26:12 umbrel external storage mounter[511]: Copying Umbrel install to external storage...
Oct 16 13:26:14 umbrel external storage mounter[511]: Copying Docker data directory to external storage...
Oct 21 02:06:36 umbrel external storage mounter[511]: Bind mounting external storage over local Umbrel installation...
Oct 21 02:06:36 umbrel external storage mounter[511]: Bind mounting external storage over local Docker data dir...
Oct 21 02:06:36 umbrel external storage mounter[511]: Bind mounting external storage to /swap
Oct 21 02:06:37 umbrel external storage mounter[511]: Bind mounting SD card root at /sd-card...
Oct 21 02:06:37 umbrel external storage mounter[511]: Checking Umbrel root is now on external storage...
Oct 21 02:06:40 umbrel external storage mounter[511]: Checking /var/lib/docker is now on external storage...
Oct 21 02:06:40 umbrel external storage mounter[511]: Checking /swap is now on external storage...
Oct 21 02:06:40 umbrel external storage mounter[511]: Setting up swapfile
Oct 21 02:06:40 umbrel external storage mounter[511]: rm: cannot remove '/swap/swapfile': No such file or directory
Oct 21 02:06:40 umbrel external storage mounter[511]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Oct 21 02:06:40 umbrel external storage mounter[511]: no label, UUID=e0cc3e80-9a0f-46f9-b3f3-8a6a2360dc06
Oct 21 02:06:40 umbrel external storage mounter[511]: Checking SD Card root is bind mounted at /sd-root...
Oct 21 02:06:40 umbrel external storage mounter[511]: Starting external drive mount monitor...
Oct 21 02:06:40 umbrel external storage mounter[511]: Mount script completed successfully!
Oct 21 02:06:40 umbrel systemd[1]: Started External Storage Mounter.
-- Logs begin at Mon 2023-10-16 13:25:49 UTC, end at Thu 2023-11-16 12:17:01 UTC. --
Oct 21 02:06:43 umbrel systemd[1]: Starting External Storage SDcard Updater...
Oct 21 02:06:43 umbrel external storage updater[2262]: Checking if SD card Umbrel is newer than external storage...
Oct 21 02:06:43 umbrel external storage updater[2262]: No, SD version is not newer, exiting.
Oct 21 02:06:43 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Uploading backup...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:02 --:--:--     0
100  4275    0     0  100  4275      0   1192  0:00:03  0:00:03 --:--:--  1192
100  4421  100   146  100  4275     35   1049  0:00:04  0:00:04 --:--:--  1085
{"message":"Successfully uploaded backup 1700061110749.tar.gz.pgp for backup ID 3e5294bd66279629a2f5aeac0be7c2edbb0dfbb18139330de479992269d169c1"}
====== Backup success =======
Got signal: backup
karen is getting triggered!
Deriving keys...
Creating backup...
Adding random padding...
1+0 records in
1+0 records out
6709 bytes (6.7 kB, 6.6 KiB) copied, 0.000332865 s, 20.2 MB/s
Creating encrypted tarball...
backup/
backup/.padding
backup/channel.backup
Uploading backup...
100  7480  100   146  100  7334     39   2006  0:00:03  0:00:03 --:--:--  2046
100  7480  100   146  100  7334     39   2006  0:00:03  0:00:03 --:--:--  2045
{"message":"Successfully uploaded backup 1700088248555.tar.gz.pgp for backup ID 3e5294bd66279629a2f5aeac0be7c2edbb0dfbb18139330de479992269d169c1"}
Got signal: backup
Deriving keys...
Creating backup...
1+0 records in
1+0 records out
1382 bytes (1.4 kB, 1.3 KiB) copied, 0.00102173 s, 1.4 MB/s
backup/
backup/.padding
Uploading backup...
100  2026    0     0  100  2026      0    595  0:00:03  0:00:03 --:--:--   595
100  2172  100   146  100  2026     34    482  0:00:04  0:00:04 --:--:--   517
{"message":"Successfully uploaded backup 1700115688051.tar.gz.pgp for backup ID 3e5294bd66279629a2f5aeac0be7c2edbb0dfbb18139330de479992269d169c1"}
Got signal: debug
Docker containers
NAMES                            STATUS
thunderhub_app_proxy_1           Up 6 days
thunderhub_web_1                 Up 6 days
ride-the-lightning_app_proxy_1   Up 3 weeks
ride-the-lightning_web_1         Up 3 weeks
ride-the-lightning_boltz_1       Up 3 weeks
lightning_app_1                  Up 3 weeks
lightning_tor_1                  Up 3 weeks
lightning_lnd_1                  Up 3 weeks
bitcoin_i2pd_daemon_1            Up 35 hours
bitcoin_server_1                 Up 3 weeks
bitcoin_app_proxy_1              Up 3 weeks
bitcoin_tor_1                    Up 3 weeks
bitcoin_bitcoind_1               Up 3 weeks
nginx                            Up 3 weeks
dashboard                        Up 3 weeks
tor_proxy                        Up 3 weeks
manager                          Up 3 weeks
auth                             Up 3 weeks
Umbrel logs
Attaching to manager
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:23 GMT] "GET /v1/system/is-sd-card-failing HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | umbrel-manager
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:23 GMT] "GET /v1/apps HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:23 GMT] "GET /v1/system/temperature HTTP/1.0" 200 2 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:23 GMT] "GET /v1/apps?installed=1 HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:23 GMT] "GET /v1/system/memory HTTP/1.0" 200 643 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:23 GMT] "GET /v1/system/storage HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:23 GMT] "GET /v1/system/info HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:23 GMT] "GET /v1/system/get-update HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:24 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 16 Nov 2023 12:55:25 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
manager      |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy    | Nov 16 02:06:54.000 [notice] While bootstrapping, fetched this many bytes: 705464 (consensus network-status fetch); 14103 (authority cert fetch); 12188163 (microdescriptor fetch)
tor_proxy    | Nov 16 02:06:54.000 [notice] While not bootstrapping, fetched this many bytes: 5992122 (consensus network-status fetch); 346188 (authority cert fetch); 19292463 (microdescriptor fetch)
tor_proxy    | Nov 16 02:06:54.000 [notice] Average packaged cell fullness: 53.365%. TLS write overhead: 2%
tor_proxy    | Nov 16 08:06:54.000 [notice] Heartbeat: Tor's uptime is 26 days 6:00 hours, with 11 circuits open. I've sent 645.07 MB and received 2.08 GB. I've received 495 connections on IPv4 and 0 on IPv6. I've made 236 connections with IPv4 and 0 with IPv6.
tor_proxy    | Nov 16 08:06:54.000 [notice] While bootstrapping, fetched this many bytes: 705464 (consensus network-status fetch); 14103 (authority cert fetch); 12188163 (microdescriptor fetch)
tor_proxy    | Nov 16 08:06:54.000 [notice] While not bootstrapping, fetched this many bytes: 6049490 (consensus network-status fetch); 353300 (authority cert fetch); 19406176 (microdescriptor fetch)
tor_proxy    | Nov 16 08:06:54.000 [notice] Average packaged cell fullness: 53.469%. TLS write overhead: 2%
tor_proxy    | Nov 16 12:47:21.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:9735. Giving up. (waiting for rendezvous desc)
App logs
bitcoin
Attaching to bitcoin_i2pd_daemon_1, bitcoin_server_1, bitcoin_app_proxy_1, bitcoin_tor_1, bitcoin_bitcoind_1
bitcoind_1     | 2023-11-16T12:44:02Z Saw new header hash=00000000000000000000b6b8c27a0b6e91113cb1b9494486e79564da2d493a88 height=817020
bitcoind_1     | 2023-11-16T12:44:02Z [net] Saw new cmpctblock header hash=00000000000000000000b6b8c27a0b6e91113cb1b9494486e79564da2d493a88 peer=6088
bitcoind_1     | 2023-11-16T12:44:04Z UpdateTip: new best=00000000000000000000b6b8c27a0b6e91113cb1b9494486e79564da2d493a88 height=817020 version=0x2477c000 log2_work=94.542086 tx=920380999 date='2023-11-16T12:43:54Z' progress=1.000000 cache=124.9MiB(568427txo)
bitcoind_1     | 2023-11-16T12:44:12Z Saw new header hash=0000000000000000000457126fd923c65a63ffc50f260dd6bd55f91a500d6ea1 height=817021
bitcoind_1     | 2023-11-16T12:44:14Z UpdateTip: new best=0000000000000000000457126fd923c65a63ffc50f260dd6bd55f91a500d6ea1 height=817021 version=0x28326000 log2_work=94.542100 tx=920386255 date='2023-11-16T12:44:01Z' progress=1.000000 cache=125.4MiB(572162txo)
bitcoind_1     | 2023-11-16T12:45:23Z New outbound peer connected: version: 70016, blocks=817021, peer=7747 (block-relay-only)
app_proxy_1    | Validating token: 4c8e0b86db3a ...
bitcoind_1     | 2023-11-16T12:49:56Z Saw new header hash=000000000000000000035f1a7807e43a132c6a40280e133fb4319cc41cd1be6b height=817022
bitcoind_1     | 2023-11-16T12:50:00Z UpdateTip: new best=000000000000000000035f1a7807e43a132c6a40280e133fb4319cc41cd1be6b height=817022 version=0x20016000 log2_work=94.542113 tx=920391454 date='2023-11-16T12:49:43Z' progress=1.000000 cache=126.4MiB(579321txo)
bitcoind_1     | 2023-11-16T12:53:43Z New outbound peer connected: version: 70015, blocks=817022, peer=7749 (block-relay-only)
bitcoind_1     | 2023-11-16T12:55:17Z New outbound peer connected: version: 70016, blocks=817022, peer=7750 (block-relay-only)
tor_1          | Nov 16 08:15:15.000 [notice] Heartbeat: Tor's uptime is 26 days 6:00 hours, with 21 circuits open. I've sent 1.40 GB and received 3.70 GB. I've received 4403 connections on IPv4 and 0 on IPv6. I've made 58 connections with IPv4 and 0 with IPv6.
tor_1          | Nov 16 08:15:15.000 [notice] While bootstrapping, fetched this many bytes: 706091 (consensus network-status fetch); 14103 (authority cert fetch); 12194489 (microdescriptor fetch)
tor_1          | Nov 16 08:15:15.000 [notice] While not bootstrapping, fetched this many bytes: 6076370 (consensus network-status fetch); 202618 (authority cert fetch); 19447987 (microdescriptor fetch)
tor_1          | Nov 16 08:15:15.000 [notice] Average packaged cell fullness: 63.001%. TLS write overhead: 3%
i2pd_daemon_1  | 12:33:40@738/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 12:34:48@738/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 12:34:48@818/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 12:43:05@682/error - TunnelMessage: Incomplete message 1791164107 already exists
i2pd_daemon_1  | 12:44:34@818/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 12:48:49@738/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 12:49:49@738/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 12:53:06@794/error - NetDb: Wp6zEkJ1xTqwaXyuPx5N~yi~oduElGfXRhlea9DMvM0= destination requested, but no tunnels found
i2pd_daemon_1  | 12:53:49@738/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
server_1       | umbrel-middleware
server_1       | ::ffff:10.21.0.2 - - [Thu, 09 Nov 2023 16:00:26 GMT] "GET /v1/bitcoind/info/sync HTTP/1.1" 200 103 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
server_1       |
server_1       | ::ffff:10.21.0.2 - - [Wed, 15 Nov 2023 13:55:53 GMT] "GET / HTTP/1.1" 200 1003 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
server_1       |
server_1       | ::ffff:10.21.0.2 - - [Wed, 15 Nov 2023 13:55:54 GMT] "GET /js/app.7c65124e.js HTTP/1.1" 200 66599 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
server_1       |
lightning
Attaching to lightning_app_1, lightning_app_proxy_1, lightning_tor_1, lightning_lnd_1
app_1        | umbrel-lightning
app_1        | ::ffff:10.21.0.4 - - [Thu, 16 Nov 2023 12:55:28 GMT] "GET /v1/lnd/lightning/payments HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
app_1        |
app_1        | ::ffff:10.21.0.4 - - [Thu, 16 Nov 2023 12:55:28 GMT] "GET /v1/lnd/transaction HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
app_1        |
app_1        | ::ffff:10.21.0.4 - - [Thu, 16 Nov 2023 12:55:28 GMT] "GET /v1/lnd/channel HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
app_1        |
lnd_1        | 2023-11-16 12:49:41.121 [INF] CRTR: Processed channels=0 updates=66 nodes=2 in last 1m0.00015881s
lnd_1        | 2023-11-16 12:50:01.827 [INF] CRTR: Pruning channel graph using block 000000000000000000035f1a7807e43a132c6a40280e133fb4319cc41cd1be6b (height=817022)
lnd_1        | 2023-11-16 12:50:01.894 [INF] CRTR: Block 000000000000000000035f1a7807e43a132c6a40280e133fb4319cc41cd1be6b (height=817022) closed 0 channels
lnd_1        | 2023-11-16 12:50:02.045 [INF] NTFN: New block: height=817022, sha=000000000000000000035f1a7807e43a132c6a40280e133fb4319cc41cd1be6b
lnd_1        | 2023-11-16 12:50:02.046 [INF] UTXN: Attempting to graduate height=817022: num_kids=0, num_babies=0
lnd_1        | 2023-11-16 12:50:41.121 [INF] CRTR: Processed channels=0 updates=49 nodes=0 in last 59.99964688s
lnd_1        | 2023-11-16 12:51:41.121 [INF] CRTR: Processed channels=0 updates=102 nodes=0 in last 59.999260216s
lnd_1        | 2023-11-16 12:52:41.121 [INF] CRTR: Processed channels=0 updates=98 nodes=4 in last 1m0.000063683s
lnd_1        | 2023-11-16 12:53:41.121 [INF] CRTR: Processed channels=0 updates=94 nodes=10 in last 59.999371116s
lnd_1        | 2023-11-16 12:54:41.122 [INF] CRTR: Processed channels=0 updates=148 nodes=0 in last 1m0.000802013s
tor_1        | Nov 16 04:48:33.000 [notice] No circuits are opened. Relaxed timeout for circuit 33519 (a Measuring circuit timeout 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 15060 seconds]
tor_1        | Nov 16 05:54:36.000 [notice] No circuits are opened. Relaxed timeout for circuit 33611 (a Measuring circuit timeout 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [2 similar message(s) suppressed in last 3960 seconds]
tor_1        | Nov 16 07:45:33.000 [warn] Received http status code 404 ("Not found") from server 185.120.145.83:9001 while fetching "/tor/keys/fp/D586D18309DED4CD6D57C18FDB97EFA96D330566".
tor_1        | Nov 16 07:46:37.000 [notice] No circuits are opened. Relaxed timeout for circuit 33735 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [4 similar message(s) suppressed in last 6720 seconds]
tor_1        | Nov 16 09:15:33.000 [warn] Received http status code 404 ("Not found") from server 185.120.145.83:9001 while fetching "/tor/keys/fp/D586D18309DED4CD6D57C18FDB97EFA96D330566".
tor_1        | Nov 16 09:17:04.000 [notice] No circuits are opened. Relaxed timeout for circuit 33852 (a Hidden service: Establishing introduction point 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 5460 seconds]
tor_1        | Nov 16 10:04:30.000 [notice] Heartbeat: Tor's uptime is 23 days 0:00 hours, with 19 circuits open. I've sent 456.51 MB and received 364.89 MB. I've received 0 connections on IPv4 and 0 on IPv6. I've made 80 connections with IPv4 and 0 with IPv6.
tor_1        | Nov 16 10:04:30.000 [notice] While bootstrapping, fetched this many bytes: 707852 (consensus network-status fetch); 14103 (authority cert fetch); 12228915 (microdescriptor fetch)
tor_1        | Nov 16 10:04:30.000 [notice] While not bootstrapping, fetched this many bytes: 8072410 (consensus network-status fetch); 96857 (authority cert fetch); 16452364 (microdescriptor fetch)
ride-the-lightning
Attaching to ride-the-lightning_app_proxy_1, ride-the-lightning_web_1, ride-the-lightning_boltz_1
boltz_1      | INFO : 2023/10/25 01:02:56 Recovering pending Reverse Swaps
boltz_1      | INFO : 2023/10/25 01:02:56 Connected to LND block epoch stream
boltz_1      | WARN : 2023/10/25 01:02:56 Could not find TLS certificate or key
boltz_1      | INFO : 2023/10/25 01:02:56 Generating new TLS certificate and key
boltz_1      | INFO : 2023/10/25 01:02:56 Loaded TLS certificate and key
boltz_1      | INFO : 2023/10/25 01:02:56 Enabling Macaroon authentication
boltz_1      | WARN : 2023/10/25 01:02:56 Could not find Macaroons
boltz_1      | INFO : 2023/10/25 01:02:56 Generating new Macaroons
boltz_1      | INFO : 2023/10/25 01:02:56 Starting REST server on: 0.0.0.0:9003
boltz_1      | INFO : 2023/10/25 01:02:56 Starting RPC server on: 127.0.0.1:9002
web_1        | [10/25/2023, 1:02:58 AM] INFO: RTL => Server is up and running, please open the UI at http://localhost:3001 or your proxy configured url.
web_1        |
web_1        | [10/25/2023, 1:03:24 AM] ERROR: Database => Database Load Error: {"errno":-13,"syscall":"mkdir","code":"EACCES","path":"/RTL/database"}
web_1        |
web_1        | [10/25/2023, 11:41:42 AM] ERROR: Authenticate => Invalid Password! Failed IP ::ffff:10.21.0.1: {"error":"Invalid password."}
web_1        |
thunderhub
Attaching to thunderhub_app_proxy_1, thunderhub_web_1
web_1        | {
web_1        |   message: 'Signed Amboss login message',
web_1        |   level: 'debug',
web_1        |   timestamp: '2023-11-09T15:16:27.854Z'
web_1        | }
web_1        | {
web_1        |   message: 'Got Amboss login token',
web_1        |   timestamp: '2023-11-09T15:16:28.057Z'
web_1        | }
==== Result ====
==== END =====
