Hello all.
I recently had a problem with my node and had to reflash the SD card and synch all the blockchain back.
I did it with the mnemonic seed and I just finished to synch 100% today.
After that, I followed the guide to restore LN channels from the Guide section here.
After rebooting my Umbrel, still 0 BTC and 0 channels.
I can see my remaining on-chain BTC while restoring with BlueWallet.
Did I miss something in the process ?
Thanks for you help.
Update, the Umbrel logs:
0.4.4
Flashed OS version
v0.4.4
Raspberry Pi Model
Revision : c03114
Serial : 100000001edfe56d
Firmware
Sep 28 2021 11:27:35
Copyright (c) 2012 Broadcom
version 778b6a4f3c7d8d48bb63c02c47bcfbac79417bea (clean) (release) (start)
Temperature
temp=44.8'C
Throttling
throttled=0x0
Mem: 3.8G 1.2G 67M 2.0M 2.5G 2.5G
Swap: 4.1G 56M 4.0G
total: 32.5%
bitcoin: 11%
system: 7%
electrs: 6.5%
mempool: 3.6%
lnd: 3.1%
ride-the-lightning: 0.8%
tor: 0.5%
Memory monitor logs
2021-10-13 12:12:34 Memory monitor running!
2021-10-19 19:04:52 Memory monitor running!
2021-10-19 19:33:10 Memory monitor running!
2021-10-20 04:28:27 Memory monitor running!
2021-10-20 06:54:25 Memory monitor running!
/dev/root 30G 2.9G 25G 11% /
/dev/sda1 916G 485G 385G 56% /home/umbrel/umbrel
Startup service logs
Oct 20 06:54:34 umbrel umbrel startup[1035]: Creating lnd ...
Oct 20 06:54:36 umbrel umbrel startup[1035]: Creating nginx ... done
Oct 20 06:54:36 umbrel umbrel startup[1035]: Creating bitcoin ...
Oct 20 06:54:37 umbrel umbrel startup[1035]: Creating lnd ... done
Oct 20 06:54:53 umbrel umbrel startup[1035]: Creating bitcoin ... done
Oct 20 06:54:53 umbrel umbrel startup[1035]: Creating neutrino-switcher ...
Oct 20 06:54:53 umbrel umbrel startup[1035]: Creating middleware ...
Oct 20 06:54:56 umbrel umbrel startup[1035]: Creating middleware ... done
Oct 20 06:54:57 umbrel umbrel startup[1035]: Creating neutrino-switcher ... done
Oct 20 06:54:57 umbrel umbrel startup[1035]: Removing status server iptables entry...
Oct 20 06:54:57 umbrel umbrel startup[1035]: Removed existing iptables entry.
Oct 20 06:54:57 umbrel umbrel startup[1035]: Starting installed apps...
Oct 20 06:54:57 umbrel umbrel startup[1035]: Starting app mempool...
Oct 20 06:54:57 umbrel umbrel startup[1035]: Starting app ride-the-lightning...
Oct 20 06:55:02 umbrel umbrel startup[1035]: Creating ride-the-lightning_loop_1 ...
Oct 20 06:55:02 umbrel umbrel startup[1035]: Creating ride-the-lightning_web_1 ...
Oct 20 06:55:05 umbrel umbrel startup[1035]: Creating mempool_mariadb_1 ...
Oct 20 06:55:05 umbrel umbrel startup[1035]: Creating mempool_web_1 ...
Oct 20 06:55:06 umbrel umbrel startup[1035]: Creating mempool_api_1 ...
Oct 20 06:55:08 umbrel umbrel startup[1035]: Creating ride-the-lightning_loop_1 ... done
Oct 20 06:55:08 umbrel umbrel startup[1035]: Creating ride-the-lightning_web_1 ... done
Oct 20 06:55:19 umbrel umbrel startup[1035]: Creating mempool_api_1 ... done
Oct 20 06:55:19 umbrel umbrel startup[1035]: Creating mempool_mariadb_1 ... done
Oct 20 06:55:19 umbrel umbrel startup[1035]: Creating mempool_web_1 ... done
Oct 20 06:55:20 umbrel umbrel startup[1035]: Umbrel is now accessible at
Oct 20 06:55:20 umbrel umbrel startup[1035]: http://umbrel.local
Oct 20 06:55:20 umbrel umbrel startup[1035]: http://192.168.1.116
Oct 20 06:55:20 umbrel systemd[1]: Started Umbrel Startup Service.
Oct 20 06:58:31 umbrel passwd[7812]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
-- Logs begin at Thu 2019-02-14 10:11:58 UTC, end at Wed 2021-10-20 07:17:01 UTC. --
Oct 20 06:54:09 umbrel systemd[1]: Starting External Storage Mounter...
Oct 20 06:54:09 umbrel external storage mounter[478]: Running external storage mount script...
Oct 20 06:54:10 umbrel external storage mounter[478]: Found device "JMicron Generic"
Oct 20 06:54:10 umbrel external storage mounter[478]: Blacklisting USB device IDs against UAS driver...
Oct 20 06:54:10 umbrel external storage mounter[478]: Rebinding USB drivers...
Oct 20 06:54:10 umbrel external storage mounter[478]: Checking USB devices are back...
Oct 20 06:54:10 umbrel external storage mounter[478]: Waiting for USB devices...
Oct 20 06:54:11 umbrel external storage mounter[478]: Waiting for USB devices...
Oct 20 06:54:12 umbrel external storage mounter[478]: Checking if the device is ext4...
Oct 20 06:54:12 umbrel external storage mounter[478]: Yes, it is ext4
Oct 20 06:54:12 umbrel external storage mounter[478]: Checking if device contains an Umbrel install...
Oct 20 06:54:12 umbrel external storage mounter[478]: Yes, it contains an Umbrel install
Oct 20 06:54:12 umbrel external storage mounter[478]: Bind mounting external storage over local Umbrel installation...
Oct 20 06:54:12 umbrel external storage mounter[478]: Bind mounting external storage over local Docker data dir...
Oct 20 06:54:12 umbrel external storage mounter[478]: Bind mounting external storage to /swap
Oct 20 06:54:12 umbrel external storage mounter[478]: Bind mounting SD card root at /sd-card...
Oct 20 06:54:12 umbrel external storage mounter[478]: Checking Umbrel root is now on external storage...
Oct 20 06:54:13 umbrel external storage mounter[478]: Checking /var/lib/docker is now on external storage...
Oct 20 06:54:13 umbrel external storage mounter[478]: Checking /swap is now on external storage...
Oct 20 06:54:13 umbrel external storage mounter[478]: Setting up swapfile
Oct 20 06:54:14 umbrel external storage mounter[478]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Oct 20 06:54:14 umbrel external storage mounter[478]: no label, UUID=bf039f77-0211-404f-8ebe-fbba93a4fd1f
Oct 20 06:54:14 umbrel external storage mounter[478]: Checking SD Card root is bind mounted at /sd-root...
Oct 20 06:54:14 umbrel external storage mounter[478]: Starting external drive mount monitor...
Oct 20 06:54:14 umbrel external storage mounter[478]: Mount script completed successfully!
Oct 20 06:54:14 umbrel systemd[1]: Started External Storage Mounter.
Oct 20 06:54:24 umbrel systemd[1]: Starting External Storage SDcard Updater...
Oct 20 06:54:24 umbrel external storage updater[958]: Checking if SD card Umbrel is newer than external storage...
Oct 20 06:54:24 umbrel external storage updater[958]: No, SD version is not newer, exiting.
Oct 20 06:54:24 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Got signal:
karen is getting triggered!
./karen: line 68: /home/umbrel/umbrel/events/triggers/: Is a directory
Got signal:
Got signal: change-password
Got signal: backup
Deriving keys...
Creating backup...
Adding random padding...
1+0 records in
1+0 records out
1753 bytes (1.8 kB, 1.7 KiB) copied, 0.000268644 s, 6.5 MB/s
Creating encrypted tarball...
backup/
backup/.padding
backup/channel.backup
Uploading backup...
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 2391 0 0 100 2391 0 1355 0:00:01 0:00:01 --:--:-- 1355
100 2537 100 146 100 2391 68 1128 0:00:02 0:00:02 --:--:-- 1198
{"message":"Successfully uploaded backup 1634710888765.tar.gz.pgp for backup ID b0cb37992b1cbfc00465d8b37fef70c91ac11f3680457fe2169cba44d282dee4"}
====== Backup success =======
Got signal:
Got signal:
Got signal: debug
Docker containers
NAMES STATUS
mempool_web_1 Up 42 minutes
mempool_mariadb_1 Up 42 minutes
mempool_api_1 Up 42 minutes
ride-the-lightning_web_1 Up 42 minutes
ride-the-lightning_loop_1 Up 41 minutes
middleware Up 42 minutes
bitcoin Up 42 minutes
nginx Up 42 minutes
lnd Up 42 minutes
manager Up 42 minutes
umbrel_app_2_tor_1 Up 42 minutes
electrs Up 42 minutes
umbrel_app_3_tor_1 Up 42 minutes
tor Up 42 minutes
umbrel_app_tor_1 Up 42 minutes
dashboard Up 42 minutes
Bitcoin Core logs
Attaching to bitcoin
bitcoin | 2021-10-20T06:56:42Z P2P peers available. Skipped DNS seeding.
bitcoin | 2021-10-20T06:56:42Z dnsseed thread exit
bitcoin | 2021-10-20T06:56:57Z New outbound peer connected: version: 70016, blocks=705823, peer=6 (outbound-full-relay)
bitcoin | 2021-10-20T06:57:19Z New outbound peer connected: version: 70016, blocks=705823, peer=7 (outbound-full-relay)
bitcoin | 2021-10-20T06:57:20Z Socks5() connect to 2002:5bdb:19e8::5bdb:19e8:8333 failed: general failure
bitcoin | 2021-10-20T06:57:31Z New outbound peer connected: version: 70016, blocks=705823, peer=8 (outbound-full-relay)
bitcoin | 2021-10-20T06:57:53Z New outbound peer connected: version: 70016, blocks=705823, peer=9 (outbound-full-relay)
bitcoin | 2021-10-20T06:57:55Z New outbound peer connected: version: 70015, blocks=90010, peer=10 (outbound-full-relay)
bitcoin | 2021-10-20T06:57:56Z ERROR: AcceptBlockHeader: prev block not found
bitcoin | 2021-10-20T06:58:01Z Socks5() connect to 37.113.98.104:8333 failed: general failure
bitcoin | 2021-10-20T06:58:03Z New outbound peer connected: version: 70016, blocks=705823, peer=12 (outbound-full-relay)
bitcoin | 2021-10-20T06:58:06Z New outbound peer connected: version: 70016, blocks=705823, peer=13 (outbound-full-relay)
bitcoin | 2021-10-20T06:59:33Z New outbound peer connected: version: 70016, blocks=705823, peer=14 (outbound-full-relay)
bitcoin | 2021-10-20T07:01:22Z New outbound peer connected: version: 70016, blocks=705823, peer=16 (block-relay-only)
bitcoin | 2021-10-20T07:11:26Z UpdateTip: new best=000000000000000000080ad252b2e40e2ec7e67122641f0bc83c45730df73bd9 height=705824 version=0x20000004 log2_work=93.128473 tx=679738008 date='2021-10-20T07:11:13Z' progress=1.000000 cache=2.7MiB(20266txo)
bitcoin | 2021-10-20T07:11:57Z New outbound peer connected: version: 70016, blocks=705824, peer=18 (outbound-full-relay)
bitcoin | 2021-10-20T07:11:59Z Socks5() connect to 199.115.205.83:8333 failed: general failure
bitcoin | 2021-10-20T07:13:19Z New outbound peer connected: version: 70016, blocks=705824, peer=20 (block-relay-only)
bitcoin | 2021-10-20T07:13:44Z UpdateTip: new best=0000000000000000000a8a32b9753fafadd17273b5e491eb22b311ea28e307ab height=705825 version=0x20002004 log2_work=93.128485 tx=679738564 date='2021-10-20T07:13:20Z' progress=1.000000 cache=3.0MiB(22218txo)
bitcoin | 2021-10-20T07:17:45Z New outbound peer connected: version: 70016, blocks=705825, peer=22 (outbound-full-relay)
bitcoin | 2021-10-20T07:17:57Z ERROR: AcceptBlockHeader: prev block not found
bitcoin | 2021-10-20T07:19:37Z UpdateTip: new best=00000000000000000005bf439b1f4845f3de33c0f2711d7449926d77b18577cc height=705826 version=0x20800004 log2_work=93.128496 tx=679739634 date='2021-10-20T07:19:05Z' progress=1.000000 cache=3.5MiB(26559txo)
bitcoin | 2021-10-20T07:19:57Z Disconnecting outbound peer 10 for old chain, best known block = <none>
bitcoin | 2021-10-20T07:20:18Z New outbound peer connected: version: 70016, blocks=0, peer=23 (outbound-full-relay)
bitcoin | 2021-10-20T07:20:41Z Socks5() connect to 2a01:4f8:212:141f::2:8333 failed: general failure
bitcoin | 2021-10-20T07:23:42Z Socks5() connect to 2600:2b00:7b24:1600::baa3:8333 failed: general failure
bitcoin | 2021-10-20T07:26:20Z UpdateTip: new best=00000000000000000001fb4135691c67912a89c2172fed014df27072d4ee58c2 height=705827 version=0x20200004 log2_work=93.128508 tx=679740967 date='2021-10-20T07:26:08Z' progress=1.000000 cache=4.3MiB(31032txo)
bitcoin | 2021-10-20T07:26:25Z Socks5() connect to 2a02:1205:5044:a7d0:189f:b522:3f25:3b66:8333 failed: host unreachable
bitcoin | 2021-10-20T07:33:22Z UpdateTip: new best=00000000000000000002124f65cef2ee2c4c3e5a3c30a34161e1f8e0c42bc7c9 height=705828 version=0x20000004 log2_work=93.128519 tx=679742366 date='2021-10-20T07:33:43Z' progress=1.000000 cache=5.0MiB(36729txo)
bitcoin | 2021-10-20T07:35:36Z New outbound peer connected: version: 70016, blocks=705828, peer=26 (block-relay-only)
LND logs
Attaching to lnd
lnd | 2021-10-20 06:55:23.427 [INF] CHDB: Checking for schema update: latest_version=22, db_version=22
lnd | 2021-10-20 06:55:23.428 [INF] LTND: Database now open (time_to_open=30.795394167s)!
lnd | 2021-10-20 06:55:23.428 [INF] LTND: Waiting for wallet encryption password. Use `lncli create` to create a wallet, `lncli unlock` to unlock an existing wallet, or `lncli changepassword` to change the password of an existing wallet and unlock it.
lnd | 2021-10-20 06:55:24.529 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:25.812 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:26.453 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:29.174 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:33.614 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:35.847 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:41.605 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:45.895 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:46.098 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2021-10-20 06:55:50.376 [INF] LNWL: Opened wallet
lnd | 2021-10-20 06:55:50.377 [INF] LNWL: Dropping btcwallet transaction history
lnd | 2021-10-20 06:55:53.469 [INF] LNWL: Opened wallet
lnd | 2021-10-20 06:55:53.469 [WRN] LTND: Dropped all transaction history from on-chain wallet. Remember to disable reset-wallet-transactions flag for next start of lnd
lnd | 2021-10-20 06:55:53.669 [INF] CHRE: Primary chain is set to: bitcoin
lnd | 2021-10-20 06:55:53.693 [INF] CHRE: Initializing bitcoind backed fee estimator in CONSERVATIVE mode
lnd | 2021-10-20 06:55:53.693 [INF] LNWL: Started listening for bitcoind block notifications via ZMQ on 10.21.21.8:28332
lnd | 2021-10-20 06:55:53.694 [INF] LNWL: Started listening for bitcoind transaction notifications via ZMQ on 10.21.21.8:28333
lnd | 2021-10-20 06:55:55.884 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd | 2021-10-20 06:55:56.901 [INF] LNWL: The wallet has been unlocked without a time limit
lnd | 2021-10-20 06:55:56.908 [INF] CHRE: LightningWallet opened
lnd | 2021-10-20 06:55:57.111 [INF] SRVR: Proxying all network traffic via Tor (stream_isolation=false)! NOTE: Ensure the backend node is proxying over Tor as well
lnd | 2021-10-20 06:55:57.241 [INF] HSWC: Restoring in-memory circuit state from disk
lnd | 2021-10-20 06:55:57.247 [INF] HSWC: Payment circuits loaded: num_pending=0, num_open=0
lnd | 2021-10-20 06:55:57.284 [INF] LTND: Channel backup proxy channel notifier starting
lnd | 2021-10-20 06:55:57.285 [INF] ATPL: Instantiating autopilot with active=false, max_channels=5, allocation=0.600000, min_chan_size=20000, max_chan_size=16777215, private=false, min_confs=1, conf_target=3
lnd | 2021-10-20 06:55:57.290 [INF] LTND: Waiting for chain backend to finish sync, start_height=705823
lnd | 2021-10-20 06:55:57.935 [INF] LNWL: Started rescan from block 0000000000000000000971d14dbebdfeff552b5eed5eae817a8f5cb772243dc2 (height 681012) for 3 addresses
Tor logs
Attaching to tor
tor | Oct 20 06:54:33.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor | Oct 20 06:54:33.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor | Oct 20 06:54:33.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor | Oct 20 06:54:33.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor | Oct 20 06:54:33.000 [notice] Bootstrapped 20% (onehop_create): Establishing an encrypted directory connection
tor | Oct 20 06:54:33.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
tor | Oct 20 06:54:33.000 [notice] Bootstrapped 30% (loading_status): Loading networkstatus consensus
tor | Oct 20 06:54:35.000 [notice] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
tor | Oct 20 06:54:35.000 [notice] Bootstrapped 40% (loading_keys): Loading authority key certs
tor | Oct 20 06:54:35.000 [notice] Bootstrapped 45% (requesting_descriptors): Asking for relay descriptors
tor | Oct 20 06:54:35.000 [notice] I learned some more directory information, but not enough to build a circuit: We need more microdescriptors: we have 0/6550, and can only build 0% of likely paths. (We have 0% of guards bw, 0% of midpoint bw, and 0% of end bw (no exits in consensus, using mid) = 0% of path bw.)
tor | Oct 20 06:54:36.000 [notice] Bootstrapped 50% (loading_descriptors): Loading relay descriptors
tor | Oct 20 06:54:37.000 [notice] The current consensus contains exit nodes. Tor can build exit and internal paths.
tor | Oct 20 06:54:53.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor | Oct 20 06:54:53.000 [notice] Bootstrapped 64% (loading_descriptors): Loading relay descriptors
tor | Oct 20 06:54:53.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor | Oct 20 06:54:54.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor | Oct 20 06:54:54.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor | Oct 20 06:54:54.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor | Oct 20 06:54:54.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor | Oct 20 06:54:54.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor | Oct 20 06:54:54.000 [notice] Bootstrapped 100% (done): Done
tor | Oct 20 06:55:13.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60s after 18 timeouts and 122 buildtimes.
tor | Oct 20 06:55:57.000 [notice] New control connection opened from 10.21.21.9.
tor | Oct 20 06:56:00.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor | Oct 20 06:56:24.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor | Oct 20 06:58:01.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor | Oct 20 07:11:59.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor | Oct 20 07:26:25.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
App logs
mempool
mariadb_1 | 2021-10-20 6:55:20 0 [Note] mysqld (mysqld 10.5.12-MariaDB-1:10.5.12+maria~focal) starting as process 1 ...
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Uses event mutexes
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Number of pools: 1
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Using ARMv8 crc32 instructions
mariadb_1 | 2021-10-20 6:55:21 0 [Note] mysqld: O_TMPFILE is not supported on /tmp (disabling future attempts)
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Using Linux native AIO
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Completed initialization of buffer pool
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: 128 rollback segments are active.
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Creating shared tablespace for temporary tables
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: 10.5.12 started; log sequence number 436253; transaction id 1683
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
mariadb_1 | 2021-10-20 6:55:21 0 [Note] Plugin 'FEEDBACK' is disabled.
mariadb_1 | 2021-10-20 6:55:21 0 [Note] Server socket created on IP: '::'.
mariadb_1 | 2021-10-20 6:55:21 0 [Warning] 'proxies_priv' entry '@% root@42d1a28ae250' ignored in --skip-name-resolve mode.
mariadb_1 | 2021-10-20 6:55:21 0 [Note] InnoDB: Buffer pool(s) load completed at 211020 6:55:21
mariadb_1 | 2021-10-20 6:55:21 0 [Note] Reading of all Master_info entries succeeded
api_1 | Oct 20 07:37:30 [42] DEBUG: Mempool blocks calculated in 0.01 seconds
api_1 | Oct 20 07:37:30 [42] DEBUG: New mempool size: 856 Change: 11
api_1 | Oct 20 07:37:30 [42] DEBUG: Mempool updated in 0.315 seconds
api_1 | Oct 20 07:37:33 [42] DEBUG: Updating mempool
api_1 | Oct 20 07:37:33 [42] DEBUG: Fetched transaction 1 / 1
mariadb_1 | 2021-10-20 6:55:21 0 [Note] Added new Master_info '' to hash table
mariadb_1 | 2021-10-20 6:55:21 0 [Note] mysqld: ready for connections.
mariadb_1 | Version: '10.5.12-MariaDB-1:10.5.12+maria~focal' socket: '/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution
mariadb_1 | 2021-10-20 6:55:21 3 [Warning] Aborted connection 3 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
mariadb_1 | 2021-10-20 6:55:22 4 [Warning] Aborted connection 4 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.27' (This connection closed normally without authentication)
ride-the-lightning
loop_1 | 2021-10-20 06:55:26.408 [INF] LNDC: Connected to lnd
loop_1 | 2021-10-20 06:55:26.409 [INF] LNDC: Waiting for lnd to unlock
loop_1 | loopd exited with an error: rpc error: code = Unknown desc = wallet locked, unlock it to enable full RPC access
loop_1 | 2021-10-20 06:55:29.119 [INF] LOOPD: Version: 0.12.1-beta commit=
loop_1 | 2021-10-20 06:55:29.120 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
loop_1 | 2021-10-20 06:55:29.121 [INF] LNDC: Connected to lnd
loop_1 | 2021-10-20 06:55:29.121 [INF] LNDC: Waiting for lnd to unlock
loop_1 | 2021-10-20 06:55:33.568 [INF] LOOPD: Version: 0.12.1-beta commit=
loop_1 | 2021-10-20 06:55:33.569 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
loop_1 | 2021-10-20 06:55:33.570 [INF] LNDC: Connected to lnd
loop_1 | 2021-10-20 06:55:33.570 [INF] LNDC: Waiting for lnd to unlock
loop_1 | 2021-10-20 06:55:41.537 [INF] LOOPD: Version: 0.12.1-beta commit=
loop_1 | 2021-10-20 06:55:41.542 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
loop_1 | 2021-10-20 06:55:41.544 [INF] LNDC: Connected to lnd
loop_1 | 2021-10-20 06:55:41.544 [INF] LNDC: Waiting for lnd to unlock
loop_1 | 2021-10-20 06:55:55.829 [INF] LOOPD: Version: 0.12.1-beta commit=
loop_1 | 2021-10-20 06:55:55.830 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
loop_1 | 2021-10-20 06:55:55.831 [INF] LNDC: Connected to lnd
loop_1 | 2021-10-20 06:55:55.831 [INF] LNDC: Waiting for lnd to unlock
loop_1 | loopd exited with an error: rpc error: code = Unknown desc = the RPC server is in the process of starting up, but not yet ready to accept calls
loop_1 | 2021-10-20 06:56:22.638 [INF] LOOPD: Version: 0.12.1-beta commit=
loop_1 | 2021-10-20 06:56:22.639 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
loop_1 | 2021-10-20 06:56:22.640 [INF] LNDC: Connected to lnd
loop_1 | 2021-10-20 06:56:22.640 [INF] LNDC: Waiting for lnd to unlock
loop_1 | 2021-10-20 06:56:22.701 [INF] LNDC: lnd version: v0.13.3-beta, build tags 'autopilotrpc,signrpc,walletrpc,chainrpc,invoicesrpc,watchtowerrpc,monitoring'
loop_1 | 2021-10-20 06:56:22.701 [INF] LNDC: Using network mainnet
loop_1 | 2021-10-20 06:56:22.701 [INF] LNDC: Waiting for lnd to be fully synced to its chain backend, this might take a while
==== Result ====
