I see an alarmingly small amount of information regarding Tor on Umbrel’s main webpages. I think there should be very clear guidelines for each node operator to verify that their traffic is encrypted between the node and the ISP.
How can I verify that the outgoing connection is over Tor?
I assume the blockchain is not downloaded over Tor, so how can I be sure that other connections are over Tor.
Edit: I installed Umbrel on a Linux server using Terminal.
