How do I configure network settings in Umbrel 1.1?
Hello. I want to set up a specific manual ip address, along with dns servers. Is it possible to do it?
I’m running umbrel 1.1 in a VM inside proxmox.
Thank you in advance for any help.
I have the same question!
How to use a fixed IP via settings?
It’s Debian Bookworm, so you still have the option to ssh in and run nmtui to configure the network.
you will find the answer on this Guide…
Tho the OP no longer works, I ground down to a solution and posted it in the comments
Start at the bottom, not the top :grinning:
Thank you!
That worked.
