Hi.
I have install Umbrel 1.1 on RPi5 and install Homebridge where need to update Homebridge to 1.8.0 and UI to 4.56.1. Update is installed correctly and when I restart HB service it is working but when I have tried to restart container it will not start and after restart HB from Umbrel is there old version. I have tried even update Node JS from HB terminal then updated HB and same status.
What should be done to correct update Homebridge?
Thanks
Richi
edit: need to have the lattest version because I have been running HB on another RPi long time and backup is not able to restore to this old version of HB
