Hello, looking to install Umbrel OS since I think its the closest thing I can get to a Synology DSM experience. But I wanted to ask a few questions first.
For apps like Frigate, I want to use my GPU and Google Coral. Are GPUs and the Google Coral TPUs supported in the OS to be used in apps? My current Frigate instance is using both in docker but during my research, I haven’t seen any posts about adding a GPU or Google Coral to an Umbrel OS install.
Bonus question, can you add external links? I currently have CasaOS installed and I am testing it and instead of migrating all my apps to it, I can just add external links and call it a day.
Great to hear you’re interested in umbrelOS! Welcome to the community!
umbrelOS does not come with support for the Google Coral platform or enhanced support for GPU’s beyond what the standard Linux kernel offers. You might be able to install support through apt however modifying the system is not recommended and such modifications are lost anyway after an OTA update.
We don’t currently support adding external links on the Umbrel Home Screen, but the Heimdall app, available on the Umbrel App Store, allows you to create your own dashboard for commonly used web apps and links.
