After one year, the node (running on a RPi) failed again. It seems to be a similar problem, SDD is full.
Here is the debug log: https://pastebin.com/S9gf5yrz
And here is what i get when running “sudo du -h -a / 2>/dev/null | sort -h -r | head -n 100”: https://pastebin.com/B0fCuhjU
I tried doing sudo systemctl stop umbrel-startup && sudo rm -rf ~/umbrel/electrs/db/mainnet && sudo systemctl start umbrel-startup after a post I found with a similar problem, but to no avail.
Things I’ve done so far:
- Changing the SDD USB cable
- Re-flashing SD card
I want to avoid restoring the node and having all my channels closed.
Any ideas?
edit: this happened while I was away on a trip, so it happened suddenly.
