Feature Request: Backup Frequency Change Option (main) and two more
THANK YOU SO MUCH, enjoying the features of umbrelOS 1.5 Beta 3
Quick request. Would like to be able to update the frequency of backups, currently hourly is not editable.
I mostly use it for a Bitcoin Node, Knots, and the lightning network. I do not require hourly. Would like to reduce stress on all the systems. Of course hourly is great if you are using more regularly.
Side request, that could be more complex. Sliding in here, as a side note. I had Umbrel running on HDD. call it #1. I wanted to backup/restore to Umbrel #2 on SDD, different PC. I fully synced #2 BTC node, in advance. Then when I restored #2 from #1, it reset all node data, requiring a full sync. Request option to keep exising node data on #1, when restore, or better sync method, backup, restore BTC block data. (700 GB, est) somehow.
Also, when linking Node #2 to the NAS, for restore, it had to go and make a backup, which got a little confusing on which one I was restoring. Luckily, the size of the backup was provided and an indicator to help. #1. Option to label backup. #2 Do not backup unless approved.
DONT TAKE MY FEEDBACK AS NEGATIVE. GREAT WORK THANK YOU
I also would like to customize backup scheduling. I think umbrel backup uses kopia in the background, but I could’n’t find the related configuration file to change the default schedule manually.
Could anyone give a hint??
