Hello everyone,
my new raspberry pi 4, 8 GB RAM with 2 TB SSD arrived on Thursday. I have installed umbrel without any issues (honestly, it couldn’t be more user-friendly).
While the blockchain was still syncing I started to play around with different apps to get to know the UIs, functions, etc.
Everything was working really well. At some point I read that I can change the alias of my lighning node (http://community.umbrel.com/t/how-to-create-a-lightning-node-alias/1252), so I did and restarted the umbrel via UI as explained in the above guide (step 8), still while the blockchain was syncing.
After the restart the lightning terminal app started to give me errors. After some research I was worried that I must have messed up the lnd.conf, so I overwrote it with a default, as explained here (http://community.umbrel.com/t/default-content-lnd-conf-lightning-configuration-file/5929/2). I restarted the umbrel again (still, the blockchain sync was and isn’t finished).
Unfortunately, the errors are still there, so I think the lnd.conf wasn’t causing the problem. My funds are there (except those in the lightning pool account, because the lightning terminal doesn’t wpork), the wallet works, the channels are up, only a few specific functions don’t work (lightning terminal, in RTL the Swap/Boltz).
Those are the logs I think are relevant for my issue:
Attaching to lnd lnd | 2022-03-24 07:13:02.000 [INF] CRTR: Processed channels=1 updates=72 nodes=8 in last 59.999417443s lnd | 2022-03-24 07:14:02.001 [INF] CRTR: Processed channels=0 updates=97 nodes=20 in last 59.999992882s lnd | 2022-03-24 07:14:08.169 [INF] DISC: Broadcasting 118 new announcements in 12 sub batches lnd | 2022-03-24 07:15:02.000 [INF] CRTR: Processed channels=0 updates=61 nodes=4 in last 59.998471884s lnd | 2022-03-24 07:15:38.166 [INF] DISC: Broadcasting 131 new announcements in 14 sub batches lnd | 2022-03-24 07:16:02.000 [INF] CRTR: Processed channels=0 updates=63 nodes=8 in last 1m0.00004656s lnd | 2022-03-24 07:16:47.679 [ERR] LNWL: unable to query estimator: web API error: fee rate cache is empty lnd | 2022-03-24 07:17:02.000 [INF] CRTR: Processed channels=0 updates=163 nodes=2 in last 59.999188592s lnd | 2022-03-24 07:17:08.166 [INF] DISC: Broadcasting 183 new announcements in 17 sub batches lnd | 2022-03-24 07:18:02.000 [INF] CRTR: Processed channels=0 updates=155 nodes=12 in last 59.999683636s lnd | 2022-03-24 07:18:34.902 [INF] BTCN: Processed 1 block in the last 7m32.67s (height 728771, 2022-03-24 07:18:04 +0000 UTC) lnd | 2022-03-24 07:18:34.910 [INF] BTCN: Attempting to fetch set of un-checkpointed filters at height=728771, hash=000000000000000000018a2b56ffeb82c75f1d8138914d28b72591bc1211d37a lnd | 2022-03-24 07:18:38.166 [INF] DISC: Broadcasting 247 new announcements in 18 sub batches lnd | 2022-03-24 07:18:44.918 [INF] BTCN: Verified 1 filter header in the last 7m41.46s (height 728771, 2022-03-24 07:18:04 +0000 UTC) lnd | 2022-03-24 07:18:45.353 [INF] NTFN: New block: height=728771, sha=000000000000000000018a2b56ffeb82c75f1d8138914d28b72591bc1211d37a lnd | 2022-03-24 07:18:45.354 [INF] UTXN: Attempting to graduate height=728771: num_kids=0, num_babies=0 lnd | 2022-03-24 07:19:02.001 [INF] CRTR: Processed channels=0 updates=139 nodes=4 in last 1m0.000493535s lnd | 2022-03-24 07:19:38.166 [INF] DISC: GossipSyncer(026165850492521f4ac8abd9bd8088123446d126f648ca35e60f88177dc149ceb2): applying gossipFilter(start=0001-01-01 00:00:00 +0000 UTC, end=0001-01-01 00:00:00 +0000 UTC) lnd | 2022-03-24 07:19:38.172 [INF] DISC: GossipSyncer(0307eafebbf6583eaf3dce69181018185b193414901c029e98062455e328c76bf3): applying gossipFilter(start=2022-03-24 07:19:38.172822364 +0000 UTC m=+49307.922360729, end=2158-04-30 13:47:53.172822364 +0000 UTC) lnd | 2022-03-24 07:20:02.001 [INF] CRTR: Processed channels=0 updates=67 nodes=8 in last 1m0.000337628s lnd | 2022-03-24 07:20:08.165 [INF] DISC: Broadcasting 126 new announcements in 13 sub batches lnd | 2022-03-24 07:21:02.000 [INF] CRTR: Processed channels=0 updates=6 nodes=2 in last 59.998363292s lnd | 2022-03-24 07:21:19.272 [INF] RPCS: New transaction subscription lnd | 2022-03-24 07:21:38.165 [INF] DISC: Broadcasting 18 new announcements in 2 sub batches lnd | 2022-03-24 07:21:50.668 [INF] RPCS: Canceling transaction subscription lnd | 2022-03-24 07:22:02.000 [INF] CRTR: Processed channels=0 updates=22 nodes=0 in last 1m0.00020847s lnd | 2022-03-24 07:22:16.017 [ERR] LNWL: unable to query estimator: web API error: fee rate cache is empty lnd | 2022-03-24 07:22:29.671 [ERR] LNWL: unable to query estimator: web API error: fee rate cache is empty lnd | 2022-03-24 07:23:02.001 [INF] CRTR: Processed channels=0 updates=45 nodes=0 in last 1m0.000135279s lnd | 2022-03-24 07:23:08.165 [INF] DISC: Broadcasting 62 new announcements in 7 sub batches
lightning-terminal web_1 | 2022-03-24 07:16:50.975 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:57505->127.0.0.11:53: i/o timeout". Reconnecting... web_1 | 2022-03-24 07:17:53.963 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:40916->127.0.0.11:53: i/o timeout". Reconnecting... web_1 | 2022-03-24 07:18:13.548 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:53012->127.0.0.11:53: i/o timeout". Reconnecting... web_1 | 2022-03-24 07:19:16.212 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:39728->127.0.0.11:53: i/o timeout". Reconnecting... web_1 | 2022-03-24 07:20:13.752 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:52366->127.0.0.11:53: i/o timeout". Reconnecting... web_1 | 2022-03-24 07:20:34.987 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:43569->127.0.0.11:53: i/o timeout". Reconnecting... web_1 | 2022-03-24 07:21:13.314 [INF] LITD: Handling static file request: / web_1 | 2022-03-24 07:21:14.422 [INF] LITD: Handling static file request: / web_1 | 2022-03-24 07:21:19.026 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/GetInfo web_1 | 2022-03-24 07:21:19.151 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/GetInfo web_1 | 2022-03-24 07:21:19.156 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/SubscribeTransactions web_1 | 2022-03-24 07:21:19.186 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/GetInfo web_1 | 2022-03-24 07:21:19.188 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/SubscribeChannelEvents web_1 | 2022-03-24 07:21:19.205 [INF] LITD: Handling gRPC web request: /looprpc.SwapClient/Monitor web_1 | 2022-03-24 07:21:19.271 [INF] LITD: Handling gRPC web request: /poolrpc.Trader/NodeRatings web_1 | 2022-03-24 07:21:19.273 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/ListChannels web_1 | 2022-03-24 07:21:19.289 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/ListChannels web_1 | 2022-03-24 07:21:19.361 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/PendingChannels web_1 | 2022-03-24 07:21:19.389 [INF] LITD: Handling gRPC web request: /looprpc.SwapClient/ListSwaps web_1 | 2022-03-24 07:21:19.427 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/PendingChannels web_1 | 2022-03-24 07:21:19.436 [INF] LITD: Handling gRPC web request: /looprpc.SwapClient/ListSwaps web_1 | 2022-03-24 07:21:19.473 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/ChannelBalance web_1 | 2022-03-24 07:21:19.477 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/ChannelBalance web_1 | 2022-03-24 07:21:19.501 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/WalletBalance web_1 | 2022-03-24 07:21:19.506 [INF] LITD: Handling gRPC web request: /lnrpc.Lightning/WalletBalance web_1 | 2022-03-24 07:21:19.522 [INF] LITD: Handling gRPC web request: /litrpc.Sessions/ListSessions web_1 | 2022-03-24 07:21:19.526 [INF] LITD: Handling gRPC web request: /litrpc.Sessions/ListSessions web_1 | 2022-03-24 07:21:43.979 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:57195->127.0.0.11:53: i/o timeout". Reconnecting... web_1 | 2022-03-24 07:22:20.990 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:54508->127.0.0.11:53: i/o timeout". Reconnecting... web_1 | 2022-03-24 07:22:20.991 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:54508->127.0.0.11:53: i/o timeout". Reconnecting...
ride-the-lightning web_1 | [3/24/2022, 7:22:01 AM] INFO: Peers => Sorted Peers List Received. web_1 | web_1 | [3/24/2022, 7:22:01 AM] INFO: Graph => Graph Information Received. web_1 | web_1 | [3/24/2022, 7:22:20 AM] INFO: Switch => Getting Forwarding Events... web_1 | web_1 | [3/24/2022, 7:22:20 AM] INFO: Switch => Forwarding Events Received. web_1 | web_1 | [3/24/2022, 7:22:26 AM] INFO: RTLConf => Getting Currency Rates... web_1 | web_1 | [3/24/2022, 7:22:29 AM] INFO: Loop => Getting List Swaps... web_1 | web_1 | [3/24/2022, 7:22:29 AM] INFO: Common => Swap Options. web_1 | web_1 | [3/24/2022, 7:22:30 AM] INFO: Loop => Getting Loop Out Terms & Quotes... web_1 | web_1 | [3/24/2022, 7:22:30 AM] INFO: Common => Swap Options. web_1 | web_1 | [3/24/2022, 7:22:30 AM] ERROR: Loop => Loop Out Terms & Quotes Error: {"name":"StatusCodeError","statusCode":503,"message":"503 - {\"error\":\"all SubConns are in TransientFailure, latest connection error: connection error: desc = \\\"transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:42544->127.0.0.11:53: i/o timeout\\\"\",\"code\":14,\"message\":\"all SubConns are in TransientFailure, latest connection error: connection error: desc = \\\"transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:42544->127.0.0.11:53: i/o timeout\\\"\",\"details\":[]}","error":{"error":"all SubConns are in TransientFailure, latest connection error: connection error: desc = \"transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:42544->127.0.0.11:53: i/o timeout\"","code":14,"message":"all SubConns are in TransientFailure, latest connection error: connection error: desc = \"transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:42544->127.0.0.11:53: i/o timeout\"","details":[]},"options":{"url":"https://10.21.21.16:8081/v1/loop/out/terms","rejectUnauthorized":false,"json":true,"headers":{},"simple":true,"resolveWithFullResponse":false,"transform2xxOnly":false},"response":{"statusCode":503,"body":{"error":"all SubConns are in TransientFailure, latest connection error: connection error: desc = \"transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:42544->127.0.0.11:53: i/o timeout\"","code":14,"message":"all SubConns are in TransientFailure, latest connection error: connection error: desc = \"transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:42544->127.0.0.11:53: i/o timeout\"","details":[]},"headers":{"content-type":"application/json","trailer":"Grpc-Trailer-Content-Type","date":"Thu, 24 Mar 2022 07:22:30 GMT","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"10.21.21.16:8081","port":"8081","hostname":"10.21.21.16","hash":null,"search":null,"query":null,"pathname":"/v1/loop/out/terms","path":"/v1/loop/out/terms","href":"https://10.21.21.16:8081/v1/loop/out/terms"},"method":"GET","headers":{"accept":"application/json"}}}} web_1 | web_1 | [3/24/2022, 7:22:46 AM] ERROR: RTLConf => Get Rates Error: {"statusCode":500,"message":"Get Rates Error","error":{"name":"RequestError","message":"Error: getaddrinfo EAI_AGAIN blockchain.info","cause":{"errno":-3001,"code":"EAI_AGAIN","syscall":"getaddrinfo","hostname":"blockchain.info"},"error":{"errno":-3001,"code":"EAI_AGAIN","syscall":"getaddrinfo","hostname":"blockchain.info"},"options":{"url":"https://blockchain.info/ticker","simple":true,"resolveWithFullResponse":false,"transform2xxOnly":false}}} web_1 | web_1 | [3/24/2022, 7:22:47 AM] INFO: Authenticate => Logged out. web_1 | web_1 | [3/24/2022, 7:22:47 AM] INFO: Database => Database Saved. web_1 | web_1 | [3/24/2022, 7:22:49 AM] INFO: CLWebSocket => Disconnecting from the LND's Websocket Server... web_1 | web_1 | [3/24/2022, 7:22:49 AM] INFO: WebSocketServer => Disconnected due to 1001 : 1648106520474, Total WS clients: 0. web_1 |
After reading though the pinned messages in this forum I realize I shouldn’t have messed with the lnd.conf and restarting the umbrel multiple times while it is still syncing. However, in my defense, it’s quite hard to not play around with new hardware and the cool UI / functions umbrel offers ![]()
From my very limited understanding of the logs I would think the error has nothing to do with the fact that the blockchain is still syncing… Any hints for troubleshooting?
Thank you very much !!
