Failed loading environment
The environment named primary is unreachable.
portainer does not work after reboot umbrel
Error:
2025/03/07 02:27PM WRN github.com/portainer/portainer-ee/api/docker/local.go:83 > failed to clean up updater stack | error=“failed to list containers: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?” retry time=0
